434 CID LTx engine?
Old Jan 25, 2005 | 09:03 PM
  #16
rskrause's Avatar
Moderator
Re: 434 CID LTx engine?
Originally Posted by ejfagala
23 degree 434's is done every day and AFR makes heads that do, and can be ported even farther, to flow more then enough. A little M block is around $1800 I spent over $600 just on my splayed mains so it is what I would consider a reasonable fee. I find it interesting that when the subject of going 383 or 396 is brought up it seems that there are a lot of folks that say go 396 for the extra few $$$, the difference in rotating assembly and machine work would be around the same and the little M block is on a completely different level then the LT1 block and could easily take added stroke without worrying about grinding into a water jacket.. The 18 degree head is great but it is a completely different subject. I see plenty of TPI based 400+ CI motors being built with 23 degree heads and modified intakes such as the single plane.
Well, people may do it, that doesn't mean it makes sense. My track car is a 60 over 427 (438ci) and it has 325cc heads, which are about the right size. True, if it were a street car I would use a smaller head. But I can't see why you want to transplant the Opti and the mediocre heads to an exotic race block. It makes no sense to me. If you want a big inch small block, just ditch the LT1 (and the 23 degree heads).
Rich
Old Jan 25, 2005 | 09:06 PM
  #17
GreenDemon's Avatar
Originally Posted by ShawnMacAnanny
Well i just was saying because the opti-spark sucks. It seems like too much work for what it would be worth though. It would be nice to be able to retain OBD1 with the LT1 block though.
The opti only sucks because of it's location. From a performance standpoint, it provides very accurate ignition and fuel timing. If you change the cap and rotor to coil over plug, you've pretty much got the best sytem possible. Optical cam/crank sensors are more accurate than magnetic or hall effect. If GM hadn't been so moronic and used a gear drive (so it could sit upright) it would have been much more well received.
Old Jan 26, 2005 | 11:03 AM
  #18
CANTONRACER's Avatar
I really enjoy my LT1, have for a long time...but recently I had my eyes opened and I realized that staying on the LT1 track for where I want to go is impractical financially and a time bomb.
This being said, I have realized that to really get what I want I will be going old school SBC, dart block, 18 deg heads, probably a FAST system(still looking into this one), but basically, all I will have is a newer car body built around a bullet proof old school SBC.
You basically just have to make a goal and build a motor that can exceed it IMO.
Old Jan 26, 2005 | 12:37 PM
  #19
ejfagala's Avatar
Rich
90% of the people on this forum use there cars as street cars in one way or another so the Track Car that sits on a trailer 6 out of 7 days is not what most are looking for. If a 434 can be made in a LT1 form factor and Dart could, make the block for a similar price to the Little M (Under $2000). Then people such as my self that drive our cars every day could have a monster motor and a car with plenty of drivability and decent gas mileage. If you want to build an all out race motor then you will need the huge heads your talking about but you will also need a very light car to deal with the larger typical 18 deg. Intake runners (260cc+) not to mention the suspention work. There is a very big diference between building a motor for around $10 (My 383 was 7K) and what you spent on your race car.
Here are two 434's with 23-degree heads in the low 10's and both cars are still run on the street. Keep in mind that both of these are still Independent rear suspension and running 700R tranys.
http://temp.corvetteforum.net/c4/ski_dwn_it/
Here is his build up and flow numbers for the heads
http://temp.corvetteforum.net/c4/ski..._mods_page.htm
http://hometown.aol.com/corkvette1/myhomepage/auto.html
Old Jan 26, 2005 | 02:37 PM
  #20
Black_95Formula's Avatar
ejfagala - I see you have dynoed your setup? Very nice numbers. Boston is under 8" of snow at the moment, but as soon as the weather warms up I will be heading over to Mr. Dyno fora visit I hope I make your numbers!
Old Jan 26, 2005 | 04:02 PM
  #21
ejfagala's Avatar
I am sure you will make plenty of power. I had a miss and an exhause leak so i think there is another 6-10 in this set up easy but the motor did exactly what I desined it to do and has got better MPG then expected, gota love EFI. Good luck at the dyno and it looks like this is bostons year, both the Sox and noe the Pats.
Old Jan 26, 2005 | 07:07 PM
  #22
LT4orbust's Avatar
Wink Re: 434 CID LTx engine?
i think they both would sell good, better heads and a larger ci block, reason being ... most aren't into the technical conversions, parts replaceing is easy....imo
Old Jan 26, 2005 | 07:30 PM
  #23
Mindgame's Avatar
My next motor will be ~440 ci aluminum sbc and no... it won't be an "Lt1". That's just a waste of time & $ for an engine of this potential.
-Mindgame
Lonemechanic
Feb 19, 2015 10:29 AM
pimpss96
Feb 12, 2015 01:28 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
rje
Sep 9, 2002 12:35 PM
