408 LT1 build
Old Mar 29, 2008 | 11:03 PM
  #61
Kaj's Avatar
Kaj
video..pics??
Old Mar 29, 2008 | 11:09 PM
  #62
bombebomb's Avatar
Originally Posted by Formula408
Just wanted to let everyone know the 408 is alive! I've had it running a few times and had it up to temp a couple of times with no leaks so far. (pray for me please... lol)
It has been a interesting ordeal to say the least. Thanks for everyone's input on the subject and I will try to give updates as to weather it fails or not.
Congratz! I hope it does good for you 408 lt1 sounds mean haha.
Old Mar 30, 2008 | 11:05 AM
  #63
Blownbird355's Avatar
If you hard block before clearencing and break into the jacket will water go through the hard block?
Old Mar 30, 2008 | 11:22 AM
  #64
reamo04's Avatar
congrats man. Definately have a unique setup. Did you ever tell us what heads/cam your running?
Old Mar 30, 2008 | 11:27 AM
  #65
ssclone's Avatar
why not just build a very stoudt 400, with efi on top?
it would be cheaper, easier, and make more power (more head combinations).
aaron
Old Mar 30, 2008 | 12:00 PM
  #66
Formula408's Avatar
I have heard hard block cracks easily and will leak, but I honestly don't know. I used devcon to fill and fluid weld on the hole.
My cam is 270 280 at .050 .711 .691 lift on a 110 +4. piston to valve is at minimum on intake has plenty on ex. Heads are trick flows with miild port job.
As for building a stoudt 400 with efi, sure why not if that's what you want. I wanted to keep it an lt1. We have one advantage as LT1 owners and that is reverse flow cooling, higher compression without racegas why not utilize it?
So many options so little money, you gotta pick one!
I'm working on the pics.
Old Mar 30, 2008 | 12:20 PM
  #67
FivePoint7z28's Avatar
The man wants to build a 408. Let him build a 408! Geez. Why not do this why not do that...... yadda yadda yadda. Because its a 408 LT1 build project thats why. I think its an interesting project and cant wait to see it done.
Old Mar 30, 2008 | 01:46 PM
  #68
ssclone's Avatar
i not going against him, but was thinking for less money, and more reliability, he could have done a 40 over 400.
but he has a good point about reverse cooling.
hey im still with you on building a 408 from a 350, and more power to you. my response was just another thought.
aaron
Old Mar 31, 2008 | 02:48 AM
  #69
AdioSS's Avatar
West South Central Moderator
Congrats man! Glad to hear of no leaks
I thought of this thread recently because David Vizard recently did an article about building a 408 out of a 350 block to make 600hp NA on pump gas. I think it was in Popular Hot Rodding? I didn't like it because there were very few details mentioned. They didn't mention rod length, piston compresison height, compression ratio or any real details. It was basically a big advertisement for T&L Engines or whatever they are called.
Old Mar 31, 2008 | 10:20 AM
  #70
blkchevyz's Avatar
aaron
no way it would be cheaper, efi system would probably cost more then he put into the shortblock.
thing sounds mean as hell, i'll get a video of it when i go back over for some more tuning.
Old Mar 31, 2008 | 10:48 PM
  #71
Formula408's Avatar
Well here are a few pics of the 408 I will get video up as soon as I can...
Old Apr 2, 2008 | 01:11 PM
  #72
TitoPR221's Avatar
Originally Posted by FASTFATBOY
I would not go bigger than a 396. No need to. 383 really.
You can make 650 hp normally aspirated with a 383
David
A normally aspirated 383 would have to be turning 8,500 to 8,700 rpm to pump out 650 hp, high rpm = $$$$$$$
500 hp at 6,700 rpm would be more realistic and affordable....
Old Apr 2, 2008 | 01:19 PM
  #73
TitoPR221's Avatar
I would do 42lb injectors for that many cubes.
Other than that, let us know on dyno numbers.
David
30 lb/hr injectors are good to at least 505 hp at 85% duty cycle. If the 408 will be turning 6,200 rpm ± 100 rpm, then it'll be making about 489-505 hp normally aspirated.
Old Apr 2, 2008 | 01:33 PM
  #74
TitoPR221's Avatar
Originally Posted by rock1501
I went 383 for this very reason plus the hp to be gained from the extra 13ci cant be too much prolly 5rwhp or less
A 408 rotating at 6000 rpm should have 30 more hp than a 383 due to the additional air flow. Or to put it another way, the 408 can produce the same hp as a 383 but at a lower rpm. For example, a 408 could make 500 hp at 6,200 rpm. A 383 would need to rotate to 6,700 rpm for the same power. [Estimated numbers]
Old Apr 2, 2008 | 01:43 PM
  #75
FASTFATBOY's Avatar
I see you like math, my 383 makes 600(ish) hp on pumpgas at 6500 rpm, so the other 2700rpm is only worth 50 hp??
I have seen a 396 LT1 make 740 hp naturally aspirated and not turn past 7500 rpm. How do you explain that?
David
