4 PCM codes. Please help! Thanks
Old Apr 16, 2007 | 05:18 AM
  #16
Guest47904's Avatar
Guest
At 12:1 Id'e leave the gaps alone. What wires and ignition are you running?
Old Apr 16, 2007 | 11:35 AM
  #17
Mike96z's Avatar
So where could I get another #11? It might be bad. Does anyone have a full schematic of all of the vacuum lines? I might have some of them wrong.
Old Apr 16, 2007 | 11:36 AM
  #18
Mike96z's Avatar
I got MSD wires, MSD coil, but everything else is new but stock.
Old Apr 16, 2007 | 02:09 PM
  #19
There is a diagram of the vacuum lines on your radiator cover.
Old Apr 16, 2007 | 04:44 PM
  #20
Mike96z's Avatar
Actually, I got the LS1 ram air conversion with that radiator cover.
Old Apr 21, 2007 | 10:18 PM
  #21
Mike96z's Avatar
Alright, fixed that one EVAP code, wire was broken on the pigtail, still having probs out of the 1351, getting .600-1.5volts out of the white wire.
Old Apr 22, 2007 | 06:50 AM
  #22
Guest47904's Avatar
Guest
The 1351 will only be set during cranking. This voltage should be between 1 and 4 volts. The only way that line could be higher than that is either the ICM has an internal short, the ground was lost to the ICM, the (IC) wire is shorted to another wire that is carrying a higher voltage (like battery voltage) or the PCM has an internal problem.
That's it.
Start by checking the ground to the ICM
Old Apr 22, 2007 | 10:21 AM
  #23
Mike96z's Avatar
Well your saying it is 1 to 4 volts during cranking? On the white wire to the ICM? Doesnt take my car long to crank so hard to tell unless I shut down the fuel or ignition, should I do that? But while it was running it was .6-1.5v.
Nayr
Mar 3, 2023 08:34 PM
truecontr3
Oct 11, 2015 09:30 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
