4.11 ? streetable with a cc306
Old Apr 27, 2004 | 09:05 PM
LT4orbust's Avatar
just want to know if it's going to be very streetable in a 97 TA A4 trans,my friend says no! i say yes!!!
Old Apr 27, 2004 | 09:20 PM
Haskin Z28's Avatar
im gonna have to agree with ur friend
Old Apr 27, 2004 | 09:37 PM
LT4orbust's Avatar
rpm at 80 mph?? thats my hy speed
Old Apr 27, 2004 | 09:40 PM
LT4orbust's Avatar
come on!! the bv going down good right now, 4.11 are fine, at least that what i'm doing!!
Old Apr 28, 2004 | 10:06 AM
Fast Caddie's Avatar
With 4.11s at 80 in OD you'll be turning around 3000rpm. You'd be better off with 3.42s or 3.73s in a purely street car.
http://www.f-body.org/gears/
Old Apr 28, 2004 | 10:18 AM
badblackta's Avatar
Well my frined has that setup except with a 6 speed and it is streetable, of course he has two extra gears
Old Apr 28, 2004 | 10:27 AM
AxeGrinder30thZ's Avatar
In an auto, no way.
Old Apr 28, 2004 | 01:13 PM
350 HRSS's Avatar
I have a set of 4.11s for my 12 bolt which currently has 3.73s. I also am running the CC306. I have been tempted many times to put in the 4.11s! But I haven't. I have heard pros and cons from both sides. My mechanic that helps me out w/ everything swears on his life that I will regret it, lol
Street driving, dragstrip, sure! Highway, holy cow! It would probably be around 3500@75-80.
Old Apr 28, 2004 | 02:28 PM
Nestromo's Avatar
Everyone has a different defenition of streetable. I have a friend with a 4spd '69 Camaro with 4.10s that he drives every day.
That said, if you spend a lot of time in town it will be a lot more streetable with 4.11s than it would be with 3.42s, if you spend most of your time on the highway then reverse that.
Old Apr 28, 2004 | 02:37 PM
LT4orbust's Avatar
I think i have my answer, light highway driving, mostly around town,4.11 will do. I've been looking at that two speed gear that bolts on to the rear of the trans also, I think with 4.11's and that 2 speed ... i would have the best of both worlds, then again maybe just the 2 speed mod without the 4.11, the only problem is the cost it's a little over 2 grand for the 2 speed.... but for a 4l60e , i think that would be the cats booty
Old Apr 28, 2004 | 02:48 PM
LT4orbust's Avatar
Is there an OD gear change( internally in the trans) that can be done to help out top end?
Old Apr 28, 2004 | 03:28 PM
grygst76's Avatar
Have your tranny rebuilt with different clutch packs and I forget what else, but my older camaro with 4.10's and a th400 I got real sick of being at 3000rpm's at 80 miles an hour!!! Get a 6-speed and it will be ok..
Old Apr 28, 2004 | 04:14 PM
LT4orbust's Avatar
yours had the 400 trans , i think with the OD trans i have it wouldn't be that bad, well i hope anyways.... because the gears came in today....4.11
Old Apr 28, 2004 | 05:20 PM
grygst76's Avatar
Mine had a th400 out of a 1988 iroc..
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Nostang 96z
Sep 10, 2002 08:54 PM
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
