3rd time a lifter has failed, are there any that are good?
Old Aug 21, 2003 | 06:32 PM
ChvyCruzen's Avatar
I put in a CC305 cam with Crane OE style Hyd Roller lifters, and they have been failing out on me (pumping up and bending my pushrods, messing up my rockers) The first two times it was the exhaust lifter for cylinder number 2. I called Summit and ordered a replacement, which was free since it was a manufactor defect. NOW, a lifter has gone out again! Are these Crane lifters know to frequently fail/pump up? I am about ready to switch over to Comp lifters, are these better than the Cranes? I would think so because it is like 100 dollars more, but I dont want to remove my intake manifold every 2 weeks to replace a friggin lifter.
Old Aug 21, 2003 | 07:42 PM
Josh-'04 GTO's Avatar
Did you adjust the valve preload too tight?
Old Aug 21, 2003 | 07:55 PM
Drag Bear's Avatar
I have run the cc 306 for 2 years but with the cc R lifters with no problems. With the hy. lifters you have to be very carefull with the spring pressure. I ran about 110 on the seat and was able to turn the motor 7000 with no problem.
Old Aug 21, 2003 | 08:04 PM
Fastbird93's Avatar
A second vote for the Comp "R" lifters. Haven't heard a bad thing about them, that's why there's in my car!
Old Aug 21, 2003 | 08:12 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
sure is the lifter, and not something else??
Old Aug 21, 2003 | 08:57 PM
96 WS6's Avatar
More times than not, a reoccuring problem is the result of another less visible problem.
Old Aug 24, 2003 | 08:19 AM
slopokrodrigez's Avatar
You either have a binding problem or the retainer is contacting the rocker. I seriously doubt the lifter is the cause of the problem
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Feffman
Oct 9, 2015 05:42 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
