engine hesitate
Old Aug 21, 2003 | 01:04 PM
ttop1986's Avatar
engine hesitate
what is wrong if when you hit the gas the car hesitates then it kicks in. it only does it when the engine is colder, once it warms up its fine. the fuel injectors were cleaned out recently too. thanks.
Old Aug 24, 2003 | 08:23 AM
slopokrodrigez's Avatar
Believe that is normal. When the engine is cold, the fuel/air mix enters the cylinder and droplets form on the cylinder walls. Once the cylinder walls are hot, the droplets are not formed since they vaporize and are burned correctly.
Sounds like your ok.
Feffman
Oct 9, 2015 05:42 AM
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
IRABuss
Sep 7, 2011 09:08 PM
