396 Stroker Project Issues......Vibration @ 4k RPM & Up
Old Apr 27, 2003 | 09:51 PM
Kdub's Avatar
PROJECT VITALS:
* 396 stroker LT1 w/ aggresive hyd. roller
* Spohn adjust. TA
* Denny's "Nitrous Ready" Driveshaft (has been balanced)
* Fluidamper Harmonic Balancer
PROBLEM:
I am getting a vibration that is pretty apparent, but not violent - just annoying) and it only occurs right at 4k and above. Doesn't matter what gear I'm in or speed I'm at.
What would cause a vibration that is only RPM and not speed induced?
Thanks in advance.
Old Apr 28, 2003 | 02:14 AM
97 RedSS's Avatar
Was your engine internally balanced?
If so, you need to make sure your flywheel is nuetrally balanced..
Cody
Timberwolf
Oct 10, 2002 05:25 PM
