396 Stroker
Old Jan 24, 2006 | 05:44 PM
94Z396_0621's Avatar
396 Stroker
Hey everybody, new to the site. Thought i'd tell ya about my 396 stroker i'm in the process of building. I have a race prepared 96 Vette block i bought already machined. Its bored .45 over which cubic inches are 398 now. Bottom end will consist of: Callies Dragonslayer stroker crankshaft, Forged H-Eagle 6" rods, JE .45 over racing pistons, Oliver Billet 4 Bolt main caps with ARP studs and bolts. Canton Oil pan. I sent Bare Trick Flow castings to Loyd Elliott which he worked, Valve sizes are 2.08, 1.625 valves, LT4 intake port matched to the heads, with a Custom cam by Loyd Elliott. 36 to 38lb injectors. All this goin the a 4L60E if it holds up. Anybody else running a 396?
Old Jan 24, 2006 | 05:47 PM
jkipp84's Avatar
Re: 396 Stroker
Welcome to the board.
I don't have a 396, but that build sounds like it's going to be a lot of fun!
Is that A4 still stock?
Old Jan 24, 2006 | 05:50 PM
Re: 396 Stroker
I had it rebuilt about 2 years ago, some racing parts in the bands and such, with a Trans Go shift kit. But from what i hear they dont hold up under pressure.
Old Jan 24, 2006 | 05:53 PM
jkipp84's Avatar
Re: 396 Stroker
Well, hopefully it holds... I'm going to have mine rebuilt before slapping the new 355 LE2 combo on it. The trans is completely stock with 120k miles on it.
Old Jan 24, 2006 | 05:57 PM
1racerdude's Avatar
Re: 396 Stroker
A BUILT 4L60E is running in the 8.50's in a 'Vett with a Rossler.
http://www.rosslertrans.com/Sale4l60e1.htm
Old Jan 24, 2006 | 06:00 PM
Re: 396 Stroker
Yea i will be running a 10 bolt for now with 3.73's for now, but i will probably end up gettin a 12 bolt later. And gonna spray a 200 shot on down the road to.
Old Jan 24, 2006 | 08:48 PM
jimbob65's Avatar
Re: 396 Stroker
Originally Posted by 94Z396_0621
Yea i will be running a 10 bolt for now with 3.73's for now, but i will probably end up gettin a 10 bolt later. And gonna spray a 200 shot on down the road to.
12 bolt later right?
When you get finished and tuned give us a some numbers As you can see in my Sig...Lloyds heads worked great for me........
Old Jan 24, 2006 | 09:00 PM
Re: 396 Stroker
I'll have some numbers. I hope to have it done by the spring. I think it will put down a real nice number.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
