On a 396 engine, where do you put the timing mark on the harmonic balancer?
Old Apr 23, 2003 | 05:30 PM
BrianZ28's Avatar
I have a 396 stroker, and Iam getting ready to put the harmonic balancer on. Where do I line up the timing mark on the balancer corresponding to the crankshaft?
Old Apr 23, 2003 | 06:51 PM
96z's Avatar
96z
The balancer will only go on the hub one way so that should take care of your problem.
Old Apr 23, 2003 | 07:11 PM
anaik's Avatar
The mark on an engine from the factory points to 12 o'clock when #1 or #6 piston is at TDC. Bolt the damper to the hub, then mark the hub where the arrow on the damper points straight up. That will give you a reference when putting the hub on. That is if the hub isn't on already.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Dec 7, 2014 11:32 AM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
