396 as apposed to a 383? any drawbacks?
Old Jun 4, 2003 | 08:18 PM
thewinner's Avatar
Both require block clearancing and oil pan. both cranks cost the same right?
any issue with reliability at high rpms? just need some pros/cons of each route. I know musser had the 401 which is the 3.875 stroke and revved to 7k.
thanks
Old Jun 4, 2003 | 08:33 PM
96z's Avatar
96z
Generally a crank for a 396 will be more than 383, considerably so in some applications. You can also use your stock oil pan for a 383, myself and a majority of the board have.
IMO a 396 really isnt worth all the extra money that could be spent. The extra spent would be better placed into the heads.
Old Jun 4, 2003 | 10:06 PM
94Sleeper's Avatar
Drawbacks to a 396 over a 383: Cost
Scat cast 9000 series cranks are very at about $300. Problem is that the only cranks made for a 396 are forged and really start costing some serious money.
Old Jun 4, 2003 | 11:05 PM
thewinner's Avatar
good deal, ill have to stay with 383 then.
Old Jun 4, 2003 | 11:09 PM
dynoflog's Avatar
Yes, forged 396 cranks cost more than cast 383 cranks, but when forged they cost the same. The only draw back I see is that their aren't as many of the shelf piston choices, especially if your going with a 5.85 rod.
Old Jun 4, 2003 | 11:26 PM
TCAL95Z's Avatar
from what I've been told by several engine builders a 396 is not as durable and the rod angle isn't as good as a 383 and piston wall scuffing is a problem?
I've actually been told by some sponsors on this board that they wouldn't build one for themselves but they do because thats what their customer wants?????
Old Jun 5, 2003 | 04:20 AM
revtime's Avatar
John Hunkins ran a 396 in Thunderchicken for like 50k and when they opened up the motor it looked real good.
I would build a 355 myself but that is just me.
Old Jun 5, 2003 | 04:40 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
how much does a 383 cost?
like if i were to drive my car into a reliable shop, drop off the keys and say i want a working, 383 stroker in 2 weeks, (or whatever amount of time)
how much $$$ am i looking at?
Old Jun 5, 2003 | 05:03 AM
revtime's Avatar
Depends on the shop but I would say between 6 and 7 grand.
And that is probably on the low side.
Old Jun 5, 2003 | 05:31 AM
ZBLKHELLRZR's Avatar
How soon you looking to build your stroker? I'm getting ready to piece mine out w/in the next 2 months. Lunati forged crank 3.875, Ross custom forged pistons 10.8:1, and 5.85 lunati pro rods forged. Only have 6k on the parts this is for a 396.
Old Jun 5, 2003 | 08:58 AM
TCAL95Z's Avatar
If you go with a all forged bottom end it's going to be pretty hard not to spend around $4300 on the short block with splayed 4 bolt mains.
Figure another $2,000 for heads, a $1,000 for cam,timing chain and valve train. Depends what the shop charges for the install.
I've been quoted $600-$1500. You can spend $9000-$10,000 pretty easy.
This is n't counting things like throttlebody, injectors, headers, and are you going to replace the opti & waterpump while you have the engine out?
Depends on your budget. Combination motorsports sells a street/strip 355 short block for about $3000 that comes with forged rods, forged pistons, cam,timing chain.
I would think it would be pretty hard to get a stroker done in two weeks unless you bought a shortblock from someone in advance and the heads too. I've heard several stories of guys waiting 4-6 months to get heads back
Old Jun 5, 2003 | 09:25 AM
94SLUG's Avatar
I too would go 355, its just cheaper and easier to build. Reliability is with the 355, and with a good heads/cam 355 400rwhp is not a major problem. I spent as much on my forged 355 crank as a 383.
Old Jun 5, 2003 | 10:39 AM
thewinner's Avatar
all about connections my friend
neighbors who are avid racers are building me a short block for half the price of what combo wanted. hell combo wanted 800 to put the heads and intake on teh block!
Old Jun 5, 2003 | 10:59 PM
dynoflog's Avatar
Remeber, quality costs money and you get what you pay for. High prices usually reflect quality, at least when machining is involved.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
