396?
Old Feb 7, 2008 | 10:37 AM
transamMW's Avatar
396?
I was curious to know why not many people build a 396 stroker? I just got done building a 383 stroker and I am ready for another project, next in mind being a 396. Is it too much stress on the block? If so, what is there that I can do to help prevent an overload of stress and what can I do to make a 396 stroker more reliable?
Old Feb 7, 2008 | 11:34 AM
EVERESTZ28's Avatar
I love my 396, but knowledge people says that is better to stay in 383.
Old Feb 7, 2008 | 12:20 PM
AmericanMuscle33's Avatar
I would say most people do not build them due to the added cost(s) involved normally outweighing the benefit.
Big concerns are A: You run into way more clearance issues with a 3.875in stroke. You have to take a decent amount of material out of the block in risky areas, i.e. near water jackets.
Also, depending on how you get to the 396ci mark, I used a 6.0 rod, which limited my piston choice...due to the CH being so small. I ended up with exactly what I needed, I just had to go through Diamond to get it.
Also, I am very happy I went with the 396.
Hope this helps.
Old Feb 7, 2008 | 01:31 PM
Z28SORR's Avatar
As parts availability has improved your seeing more of these being done. My "shop" assured me that clearancing the block should not be a problem, nor should there be clearance problems with the cam.
The only added expense I've run into are the custom piston, but that is because I'm doing a blower motor.
Today it should be no more expensive than an NA 383ci.
Old Feb 7, 2008 | 02:23 PM
slomarao's Avatar
the block should be sonically checked(sp).
Old Feb 7, 2008 | 04:45 PM
SS RRR's Avatar
What added cost?
Old Feb 7, 2008 | 07:05 PM
Originally Posted by SS RRR
What added cost?
For starters how about the $900 pistons it took to achieve 1.062 ch with a 34cc inverted dome.
Also, there was over 6hrs of labor involved in clearancing the oil pan rails, bottom of the cylinders, and the rods (full base circle camshaft). Longer than a 383 would have required.
You could potentially avoid these costs by using a shorter rod, a rod with more clearance, and a small base circle cam. However, I already had a 3.875in crank, rods, and cam sitting on my floor that I would have taken a huge loss on.
I'm not trying to argue that its impossible to build a 396 for the same or less as a 383. Just letting someone know I ran into some added costs going the 396 route. Perhaps, they might run into the same problems I ran into. If thats the case, they might be able to save some coin by not making the same mistakes, or adjusting their parts "wish list".
-Andrew
Old Feb 7, 2008 | 07:15 PM
SS RRR's Avatar
-Andrew
Understood, but as you already said that's not going to be the case with everyone if they plan accordingly. Even a block stroked to a 383 will need clearencing. I too have a 396. I used Compstar 6" rods and the shop had no issues w/ clearencing. I'm using a small base circle cam. My pistons had to be custom made so they were a bit more expensive, but that had to do with using my set of LPE heads which have a 58cc chamber and I didn't want to get super crazy on the compression since it's a street car.
Ultimately the cost between the two rotating assy's and machining are extremely comperable.
Old Feb 7, 2008 | 08:04 PM
Agreed. I made the mistake of changing my mind halfway through the build. Won't happen to everyone, but happens a lot to me .
Old Feb 27, 2010 | 02:42 AM
RalphBoggero's Avatar
where did you buy the 396 rotating kit ? I want all forged and 6 " rods with 10.5 to 11.0 C.R.
Old Feb 27, 2010 | 10:26 AM
Venomous360's Avatar
Doesnt Golen make a 396 short block and long block for the LT1??
http://www.golenengineservice.com/sp...l/396_520.html
How good are these setups and is the cost worth doing it this way?? My friend almost went this route when he did his 383.
Old Feb 27, 2010 | 12:04 PM
RamAir95TA's Avatar
Why so low on the compression?
Old Feb 27, 2010 | 01:25 PM
pineapplesink6's Avatar
Can't you guys go more then 396 cubes, or is that about it? 396 just seems small these days somewhat......
I thought I saw a 409 LTx a few years ago?
Old Feb 27, 2010 | 01:33 PM
96capricemgr's Avatar
Yes you can go bigger but WHY. Performance wise the 383 works, blind faith in displacement has lead a lot of guys to spend a lot of money for little return.
An engine is a whole package, it all has to work and you are going to be hard pressed to find data to support a 396 LT1 working better than a 383.
TitoPR221
May 26, 2015 12:20 AM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
whitehooptie
Advanced Tech
Aug 28, 2002 01:51 PM
