385 Build research ?'s
Hey guys, I've been doing a lot of reading and research and think i have my setup pretty much figured out. I just want to throw it out there and see what you guys think as well as get some opinions. As the list goes so far
Lt1 385
Forged Scat Crank 3.75
Forged Scat H-beam rods 5.7
Forged pistons (haven't really decided on a brand but they will be around 12.0-1 cr)
Afr 210's or Trickflow 195's (actually looking for some opinions on this, if i get the TF's I'll be getting them from AI ported out, not sure if the AFR would get ported or not)
Cam (I'm looking hard into the Lunati Voodoo series or a custom grind. I know custom would probably work better and be tailored to my setup but i love the voodoo cams and believe one of the 2 larger ones would make enough to satisfy me. Opinions very welcome on this)
Ported intake/58mm
All needed fuel upgrades
Rebuilt trans and new beefed up clutch
All of this paired with the mods already in my sig. The car would be tuned at Futral Motorsports. Like I said this is more of a R&D thing, its pretty much certain that its going to be a 385; i'm looking mostly for input on the heads and cam. Also what do you guys think it would make either setup? Obviously this would be a ballbark kind of thing. Just for arguments sake lets say i'd like to see 450+rwhp.
Lt1 385
Ported intake/58mm
ported stock heads are best for this kind of build ~ with lighter, bigger valves (min intake 2.00 & 1.55 exhaust) all exhaust passages polished to a mirror finish, there are pictures on this board and on the web of the exact areas needing removal of materials: upper intake port, bowl, 3 angle valve job, push rod shroud-back & all around, the sharp turn on both exhaust and intake. An experienced shop will charge you about the same for labor as new aftermarket heads which have tested lightly lower on various dynos.
If your talking cheapest? Possibly!!! But usually because you already have them.
Port work depends on who is doing the porting. A guy like myself could port a set of stock heads, but they may never flow as good as a set of aftermarket heads. If done incorrectly you can even decrease the flow of the stock heads. Make sure you find a good shop to do the porting if you do. I would just pick up a set of stock heads and have them ported be advanced inductions.com or elliottsportworks.com and have them match a cam to the flow of the heads. Here is a 385 build done on ls1tech it should put down over 450 out of a m6.http://www.ls1tech.com/forums/wester...o-numbers.html the heads were done by advanced induction
The DCR for your combo is ~9.8:1, ASSuming the adv duration is 285/293. That is way high for 91 octane. Amazing that it runs well, kudos to you or your engine builder. But that's not how I would build it. My methanol burning BBC motor has SCR of ~14.2:1 and a DCR = ~9.1:1 and it does detonate a bit with optimal timing and mixture. I have to run it rich and back off the timing to avoid detonation. Costs a few ponies but helps it last. Methanol technically is 100 octane but due to the large amount of charge cooling has an "apparent" octane of ~114.
With a typical street cam, I'd advise the OP to look at about 11:1 at most.
Rich
I'm going to be running a pretty big cam, which will help to drop it some. We have 93 at the pump down here which is what it will be tuned on. I'll have Futral Motorsorts doing the tuning, i talked to them a while back and was told it wouldn't be a problem.
CARiD
Sep 30, 2015 05:44 AM
