383 vs 396 LT1
Old Dec 25, 2005 | 09:52 PM
  #16
fireman's Avatar
Re: 383 vs 396 LT1
I agree, only went 20 over on mine. Guess I got a 353ci now.
Old Dec 25, 2005 | 10:00 PM
  #17
amean94ta's Avatar
Re: 383 vs 396 LT1
its called unshrouding the valve's thats one reason bigger is beter.
also thats why they make sleves and hardblock for
Old Dec 25, 2005 | 11:50 PM
  #18
IrocSS85's Avatar
Re: 383 vs 396 LT1
I went with teh 383 for two reasons. I didnt want to use hard block which is nec. due to haveing clearence the block for the rods/longer stroke more then for a 383. the other reason is, if I remember right, it was a bit more expensive for the longer crank and pistons? I think. goin by the std. CID/HP were not talkin alot of HP/Tq diff. either. anyone know the formula?
Old Dec 26, 2005 | 05:55 AM
  #19
hairbear's Avatar
Re: 383 vs 396 LT1
Your motor reads to be almost what I'm building,cept I'm only 30 over. Was it absolutely a have'ta on the use of the Hardblock filler? Why such a high compression ratio on yours?
Old Dec 26, 2005 | 10:29 AM
  #20
amean94ta's Avatar
Re: 383 vs 396 LT1
the high compression is due to me shaving the heads to 50 cc's. compression = more power and i am going for a all out motor i dont care abot street manners
the hard block to me was something i would not have done without cause of the clearencing and for strength but i am also running a 300 shot and twisting it to 7800 rpms
biggest tip is scrap the cc306 and go straight to a custom solid roller
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
