383 stroker problems
Old Oct 10, 2007 | 05:32 PM
twind's Avatar
Hey everyone, I have a 383 stroker in my 94 camaro z28.....I just got a brand new starter put on my car and it was starting beautifully yesterday...i drove it all yesterday .... and finally let it rest @ around 12:00 yesterday. Well 2day when i went to start her ( was engine cold) she started ..then I put her into reverse ....as I started reversing she went off....I continued to try and start the car and the car responded with engine turning for a couple of sec. then shutting off... I let the car rest until just while ago...once again the car started ...then shut off moments after...I really need some help here..thanx
Old Oct 10, 2007 | 05:35 PM
Greaseymec's Avatar
Get it scanned! Gotta start there first.
Mec
Old Oct 10, 2007 | 05:41 PM
Did you check the fuel level? .... check the fuel pressure?
Old Oct 10, 2007 | 06:07 PM
rskrause's Avatar
Moderator
Did you take a good look? Sounds like something loose/disconnected.
Rich
Old Oct 11, 2007 | 12:36 AM
twind's Avatar
ok....starting tomorrow Ima take look @ these and Ill let you know ..ok..Thanx
Old Oct 11, 2007 | 04:06 PM
twind's Avatar
LT1/383 stroker
Is there any way that it could possibly be the fuel injectors? once again this morning I tried it out..i put it it in reverse went for about 15 sec..backwards..shift into Drive and gone..it died?
Old Oct 11, 2007 | 05:01 PM
rob97ss's Avatar
it could be a hundred things,if you get it to start let it idle first before you just try to move it.Does it have any codes(ses light)?check the wires on the starter you just replaced.
Old Oct 11, 2007 | 05:04 PM
chief455's Avatar
need to put fuel pressure gauge and a scan tool on it, and as mentioned - look for loose connection/broken wire where you just worked - by the starter.
Old Oct 12, 2007 | 12:40 AM
twind's Avatar
checking for mistake on 383
ok...tomorrow morning Ill check for loose wire and take it to a mechanic to check the gauges ..thanx again guys..will let you know what happens
D1SC383LT4
Jan 1, 2016 01:56 PM
Rde Bandit
Mar 21, 2015 10:17 PM
maybe2fast
Mar 13, 2015 11:48 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
