383 Stroker LT1 Build
Old Jun 7, 2010 | 11:48 AM
spilner's Avatar
388 Stroker LT1 Build
Starting from scratch here. Got a 383 .060 short block and tore it down.
Here are some parts going back in.
Weisco Pro Tru Pistons
6 in. H-Beam Rods
Everything from oil pan/pump to rocker arm studs- ARP Studs
Clevite H Series Bearings
4-bolt splayed main caps
Canton Race pan setup
Heads decked .040, Beehive springs, ported/polished. Tested on flow bench with crazy good numbers for stock heads.
Stock intake bored to accept 58mm throttle body ( still needs ported/polished, powder coated)
Thats just a jist of what I have now to get me started. The guy building the short block should have it done this week. Im hoping for 500-600 hp.
Here is the block with the caps installed. I just got it back yesterday. Have to line hone it, clean it and paint it red.
[IMG][/IMG]
[IMG][/IMG]
And here is the pan with some custom chevy decals
[IMG][/IMG]
[IMG][/IMG]
Old Jun 7, 2010 | 01:59 PM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
N/A, FI, or nitrous ?
Old Jun 7, 2010 | 02:46 PM
spilner's Avatar
At 1st it will be N/A. I will go with a super charger eventually to get some extra power.
Old Jun 8, 2010 | 07:58 AM
T/A lt1's Avatar
Well you aren't going to make 500-600HP with stock heads so what are your crazy flow numbers? I know what it takes to make 550+HP and you need at least a high 230/240@50 camshaft, 11.5+compression, good quench, Ported heads and intake setup, 1-3/4" headers with 3" exhaust and a good PCM tuner. what are you using?
Old Jun 8, 2010 | 08:07 AM
spilner's Avatar
Im getting a custom ground cam with big numbers. It will have high compression since the heads are decked .040 and I will be running atleast 100 octane. The heads are equal numbers if not better then some aftermarket heads. The best PCM tuner out there (PCM For Less) has a shop 15 minutes from me so that is all good.
Just check back in 6 months and I will show you dyno runs.
Old Jun 8, 2010 | 08:39 AM
T/A lt1's Avatar
Not saying it's not doable b/c I made 500HP with my 355" LT1 and now make quite abit more since upgrading to a higher compression 383. Just trying to help you b/c I have built what your looking to do and it can be done in variations. Are you going to stay hydraulic or go to a solid roller? What are your et goals for this setup?
Old Jun 8, 2010 | 08:49 AM
spilner's Avatar
oh yeah I appreciate any help. Im staying Hydraulic so it will be some what reliable and last I know that will hurt me on power but I do try and want to still drive it on the street and not wear out the motor as fast.
Im going to go with scorpion 1003 1.6-7/16 rockers.
I dont realy have any et goals but obviously the faster the better.
Old Jun 8, 2010 | 04:34 PM
RamAir95TA's Avatar
I'm right around 550fwhp with my 383 with a mild stroker cam on typical pump gas. Your build is easily doable.
Old Jun 8, 2010 | 08:59 PM
spilner's Avatar
thats what I was thinking. I dont see a problem but you never know until its on the chart
Old Jun 9, 2010 | 10:57 AM
T/A lt1's Avatar
Is it easily doable with unported LT1 heads that have only been milled?
Old Jun 9, 2010 | 11:51 AM
spilner's Avatar
I guess you missed my 1st post that said they have been ported/polished
edit: I will get a picture of the heads tonight and post them up.
Old Jun 9, 2010 | 01:18 PM
rskrause's Avatar
Moderator
Sounds good. However, don't buy the springs until you have a cam selected.
Old Jun 9, 2010 | 01:56 PM
spilner's Avatar
I already have springs on the heads They are the beehive springs. Guess my 1st post is hard to read just messin
Old Jun 9, 2010 | 09:35 PM
spilner's Avatar
head pics
[IMG][/IMG]
[IMG][/IMG]
Old Jun 10, 2010 | 09:32 AM
spilner's Avatar
What oil pump would you guys run on this motor. I see the melling 10554 is a good pump, but wouldnt the 10550 be better because of the extra 25% volume?
