383 stroker kit
Old Jan 11, 2008 | 06:44 AM
Twizted96Camaro's Avatar
383 stroker kit
im just looking to do a 383 stroker kit would i have to do any thing to the top end of the motor or would i be fine do i have to change fuel injectors? i herd the motor is 285 hp stock how much hp gain will i get with a 383 stroker kit and do i need to do any thing to my tranny or can i leave it stoke?
Old Jan 11, 2008 | 08:08 AM
Can we assume you have a 1996 LT1 Camaro, from your screen name? If so, I'll move this to "LT1/LT4 Engine Tech". There are numerous posts there regarding the requirements for building a stroker motor.
Briefly, in order to take advantage of the increased displacement, you need a new "top end" including better flowing heads and a more aggressive cam. Larger injectors, upgraded exhaust, larger throttle body, etc.... would all be required as well, to realize the maximum advantage of the stroker. I've seen a 383 LT1 make anywhere from 375 - 1,125HP (blown)..... how much do you want? What is your budget?
Old Jan 11, 2008 | 08:26 AM
rskrause's Avatar
Moderator
If everything else remains the same the 383 will makes the same peak power a couple of hundred rpm lower and gain maybe 30-40lb-ft of torque in the midrange. It will be a little bit quicker but not substaniitally so. If you need to rebuild because the old motor is worn out, a 383 is basically teeh same cost as a new 350 rotating assembly (if similar quality parts are used) so it may make sense. You can always upgrade the top end later. But if you have a decent running motor and are looking for more performance, put it into the top end now.
Rich
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
