383 stroker kit
Old Nov 22, 2004 | 01:54 PM
Mystic97Z's Avatar
383 stroker kit
hey, yes i used the serch button a ton, but all i find is nu-tek, and i heard they are out of business for a while or something,
have a le1 head/cam combo up top,
need a 383 or 396 stroker bottom end, having my block bored to match.
i'm trying to find a place that has that eagle steel 383 stroker kit for a lt1,
i want to buy the whole thing, not in pieces, the crank/rods/pistons/bearings everything. where can i get this?
i tried to search for the last hour, can't relly find much.
thanks
-Jason
and i am switching cams to suite a 383/396
Old Nov 22, 2004 | 02:37 PM
93turbo5oh's Avatar
Re: 383 stroker kit
www.adperformance.com
shoot them an email.
Old Nov 22, 2004 | 03:04 PM
kazman's Avatar
Re: 383 stroker kit
IMO the "off shore" eagle stuff is junk. I'm in the process of rebuilding my 383 again. This time I'm using a Crower rotating assembly. $$$$ but I don't want to have to rebuild a third time.
Old Nov 22, 2004 | 03:47 PM
Gripenfelter's Avatar
Re: 383 stroker kit
Eagle H rods
Callies/Scat crank
SRP pistons
Federal Mogul/Clevite 77/King bearings
Speed Pro/JE moly rings
etc etc.
Old Nov 22, 2004 | 03:56 PM
93turbo5oh's Avatar
Re: 383 stroker kit
all the 4340 forged stuff is chinese. callies, cola, crower, eagle, scat...the list goes on and on. the difference is in the heat treating.
Old Nov 22, 2004 | 11:28 PM
Revolutionary's Avatar
Re: 383 stroker kit
If you are looking for a pretty straightforward drop in assembly, I can put together something that is balanced so you can use your OEM damper and flywheel. Let me know what year it is and I'll also get you the right woodruff key.
The Eagle and Scat stuff is forged in China and finish machined here in the states, but Cola, Callies and Howards cranks are all forged at the Louisville Forge in KY. Not sure who forges Crowers stuff but I am 99% sure it is not overseas.
Old Nov 22, 2004 | 11:42 PM
93turbo5oh's Avatar
Re: 383 stroker kit
hmmm.......i was told they were all chinese. ill have to check into that.
Old Nov 22, 2004 | 11:46 PM
TCAL95Z's Avatar
Re: 383 stroker kit
Go on Ebay or try Flatlander racing. There are some great prices on Eagle and Scat parts on there.
Also make sure you know what bearing clearance you need when you order your bearings. I wouldn't order the bearings until your machine work is done.
Stock tolerances probably won't be what you want and you will need a certain bearing. I know this because I just made this mistake.
I don't think that Scat and Eagle make junk parts but many builders don't check things the way they should and they make a junk engine.
All depends on how much you want to spend.
There are Many people going very fast on some Factory beefed up parts, good machining and proper assembly
Old Nov 23, 2004 | 07:11 AM
kazman's Avatar
Re: 383 stroker kit
I have to agree that the engine build is critical. Super-great parts thrown together will fail. There is a world of difference between the Scat/Eagle off shore parts and the USA parts. You can go fast on anything once or twice. I bracket race and my Eagle stuff failed midway in the season (about 100 passes).
Crower stuff is made in USA however they are starting a low cost Chineese casted product line to price match Eagle and Scat.
Old Nov 23, 2004 | 02:21 PM
Mystic97Z's Avatar
Re: 383 stroker kit
i don't mind spending $$, i don't want the **** to break ya know,
i would prefer lunati but its a little to rich for me,,
where can i find that crower brand? u guys are saying that would be better than eagle?
Old Nov 23, 2004 | 05:09 PM
rskrause's Avatar
Moderator
Re: 383 stroker kit
Don't bother to check. They are forged and machined in the US. However, the steel comes from Japan, I believe. Japan is, however, a long way from China (figuratively speaking of course).
Rich
Old Nov 23, 2004 | 06:28 PM
ejfagala's Avatar
Re: 383 stroker kit
Got all my stuff from Flatlander and Sal was great to deal with.
D1SC383LT4
Jan 1, 2016 01:56 PM
Drtryder
Apr 22, 2015 04:17 PM
Sauced
Apr 12, 2015 10:18 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
