383 stroker kit
383 stroker kit
hey, yes i used the serch button a ton, but all i find is nu-tek, and i heard they are out of business for a while or something,
have a le1 head/cam combo up top,
need a 383 or 396 stroker bottom end, having my block bored to match.
i'm trying to find a place that has that eagle steel 383 stroker kit for a lt1,
i want to buy the whole thing, not in pieces, the crank/rods/pistons/bearings everything. where can i get this?
i tried to search for the last hour, can't relly find much.
thanks
-Jason
and i am switching cams to suite a 383/396
thanks
-Jason
Re: 383 stroker kit
IMO the "off shore" eagle stuff is junk. I'm in the process of rebuilding my 383 again. This time I'm using a Crower rotating assembly. $$$$ but I don't want to have to rebuild a third time.
Re: 383 stroker kit
Re: 383 stroker kit
If you are looking for a pretty straightforward drop in assembly, I can put together something that is balanced so you can use your OEM damper and flywheel. Let me know what year it is and I'll also get you the right woodruff key.
The Eagle and Scat stuff is forged in China and finish machined here in the states, but Cola, Callies and Howards cranks are all forged at the Louisville Forge in KY. Not sure who forges Crowers stuff but I am 99% sure it is not overseas.
Re: 383 stroker kit
Re: 383 stroker kit
Go on Ebay or try Flatlander racing. There are some great prices on Eagle and Scat parts on there.
Also make sure you know what bearing clearance you need when you order your bearings. I wouldn't order the bearings until your machine work is done.
Stock tolerances probably won't be what you want and you will need a certain bearing. I know this because I just made this mistake.
I don't think that Scat and Eagle make junk parts but many builders don't check things the way they should and they make a junk engine.
All depends on how much you want to spend.
There are Many people going very fast on some Factory beefed up parts, good machining and proper assembly
Re: 383 stroker kit
Crower stuff is made in USA however they are starting a low cost Chineese casted product line to price match Eagle and Scat.
Re: 383 stroker kit
i don't mind spending $$, i don't want the **** to break ya know,
i would prefer lunati but its a little to rich for me,,
where can i find that crower brand? u guys are saying that would be better than eagle?
Re: 383 stroker kit
Originally Posted by 93turbo5oh
hmmm.......i was told they were all chinese. ill have to check into that.
Rich
Drtryder
Apr 22, 2015 04:17 PM
