383 Strker Spark Plug Gap?
Old Oct 17, 2012 | 08:16 PM
Macs95LT1's Avatar
Running MSD Opti, MSD Blaster coil SVO 30lb injectors and Taylor wires. Would u keep stock gap (.050) or something else?
Old Oct 17, 2012 | 10:34 PM
Re: 383 Strker Spark Plug Gap?
I would only use the stock gap with platinum or iridium plugs. With standard plugs, drop it down to 0.035 - 0.040". If you are over 400HP at the flywheel, run one stop colder than stock. All this assumes you are not running a power adder like forced induction or nitrous.
Old Oct 18, 2012 | 04:53 AM
RamAir95TA's Avatar
FWIW my setup below uses NGK TR6s gapped at .035" (one step colder than stock as Fred mentioned).
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
