383 Spark Plug Help!
Old 10-15-2004, 10:58 AM
Deenasty's Avatar
I need a spark plug reccomendation for a 383 10.4:1 Comp. Its got AFR heads, so I need a gasketed plug. AFR reccomends to start with the AC FR3LS. Should I start out colder? I currently run the NGK BKR5E. The motor runs hot, not the temp gauge, but When I open my hood after a drive, the engine compartment is suppper hot. What do you guys reccomend, and gapped at what? Thanks!
Deenasty is offline
Old 10-15-2004, 11:23 AM
Z28barnett's Avatar
Re: 383 Spark Plug Help!
The spark plugs will have no effect at all on how hot the engine runs.
If that is the problem that you are trying to solve, look in other areas. You could try a new thermostat, waterwetter, check the fan operation and so on.
Heat range on a plug is how hot does the firing tip gets when the engine is running. As long as it gets hot enough to burn off carbon and stays cool enough to avoid melting down, thats as good as it gets.
Z28barnett is offline
Old 10-15-2004, 11:46 AM
WS Sick's Avatar
Its a general rule that the more Horsepower you add to a motor whatever the method, you should go down in heatrange of the plug to stave off detonation. I am using the Autolite 104s in my 383 and they selfclean very well.
WS Sick is offline
Old 10-15-2004, 12:29 PM
Deenasty's Avatar
z28: I dont mean the coolant is hot or the car is overheating, just the motor is letting out a lot of heat.
Ws: AFR reccomended me the Autolite 3910...its a gasketed plug, because I have the AFR's..
Deenasty is offline
Old 10-15-2004, 01:36 PM
WS Sick's Avatar
Hmm, My AFRs have a factory style taper.
WS Sick is offline
Old 10-15-2004, 02:41 PM
Deenasty's Avatar
really, all AFR's are flat taper, requiring a gasketed plug...check them out
www.airflowresearch.com
Deenasty is offline
Old 10-15-2004, 04:04 PM
1racerdude's Avatar
Extra under hood heat could be caused by a header change and not being coated with ceramic.
More HP will bring more heat,not water heat but heat from heads,exhaust,block,ect.
1racerdude is offline
Old 10-15-2004, 04:20 PM
SS MPSTR's Avatar
Absolutely correct.
SS MPSTR is offline
Old 10-15-2004, 08:47 PM
Deenasty's Avatar
my headers are ceramic coated...
Deenasty is offline
Old 10-17-2004, 10:37 PM
5.7LT1Formula's Avatar
i just fired up my 383 with bosh platnium plus 4's..expensive..but i like them..also have a friend running them in his highly modd. engine and runs just as good.
5.7LT1Formula is offline
Old 10-18-2004, 10:24 AM
WS Sick's Avatar
Says there they used the gasketed plugs, hmm. I wonder. I looked my heads over good and they have a tapered seat, the plugs seal good as well. I wonder if my machinist did something. Or maybe I've just been using the wrong plugs....lol
WS Sick is offline
Old 10-18-2004, 10:28 AM
WS Sick's Avatar
In the 3910 Autolites is that equal to the factory heat range or is it a step colder? I might see if they fit better and use those instead. I want 1 heat range colder than stock and autolites site is no help...lol
WS Sick is offline
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
blkWidow
05-03-2015 08:42 AM
nikko
04-20-2015 07:56 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: 383 Spark Plug Help!
