Help, need your opinions!
Hey guys,
Took my 96 Z28 to Merchants for routine work -- wheel balancing and rotating, radiator flush, and fuel system cleaning. Got it back and noticed a profuse leak and also my power steering was struggling as the car was parked and I was turning the wheel. The liquid leaking is most likely power steering fluid. Any ideas as to how they could have caused this by doing the above mentioned work, so that at least I know what to talk about when I go back? Thanks, any help would be appreciated!
Re: Help, need your opinions!
I don't know what they did exactly. Just take it over there and tell them it was leaking and the steering felt heavy after they worked on it. Make them figure out what they did wrong. Be nice at first, but if they try to give you the run around stand your ground.
