383 Spark Plug Help!
I need a spark plug reccomendation for a 383 10.4:1 Comp. Its got AFR heads, so I need a gasketed plug. AFR reccomends to start with the AC FR3LS. Should I start out colder? I currently run the NGK BKR5E. The motor runs hot, not the temp gauge, but When I open my hood after a drive, the engine compartment is suppper hot. What do you guys reccomend, and gapped at what? Thanks!
Re: 383 Spark Plug Help!
The spark plugs will have no effect at all on how hot the engine runs.
If that is the problem that you are trying to solve, look in other areas. You could try a new thermostat, waterwetter, check the fan operation and so on.
Heat range on a plug is how hot does the firing tip gets when the engine is running. As long as it gets hot enough to burn off carbon and stays cool enough to avoid melting down, thats as good as it gets.
Its a general rule that the more Horsepower you add to a motor whatever the method, you should go down in heatrange of the plug to stave off detonation. I am using the Autolite 104s in my 383 and they selfclean very well.
z28: I dont mean the coolant is hot or the car is overheating, just the motor is letting out a lot of heat.
Ws: AFR reccomended me the Autolite 3910...its a gasketed plug, because I have the AFR's..
Originally Posted by WS Sick
Hmm, My AFRs have a factory style taper.
www.airflowresearch.com
Extra under hood heat could be caused by a header change and not being coated with ceramic.
More HP will bring more heat,not water heat but heat from heads,exhaust,block,ect.
really, all AFR's are flat taper, requiring a gasketed plug...check them out
In the 3910 Autolites is that equal to the factory heat range or is it a step colder? I might see if they fit better and use those instead. I want 1 heat range colder than stock and autolites site is no help...lol
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
