383 running... now bad stutter over 5200
Old Mar 22, 2004 | 10:45 PM
94_Camaro_LT-1's Avatar
Pulls really hard through the rpms till about 5200 until it shift it stutters/misses really bad... All the plugs are new and wires... Opti has about 18k on it... I have 2 freescan readings if that would help??? If any more info is needed let me know, I don't know what else to do
Old Mar 22, 2004 | 11:50 PM
OBE1 95Z28's Avatar
Have you checked your fuel pressure to make sure it's not dropping off above 5K rpm? Did you have your PCM reprogrammed to "feed" the 383?
Old Mar 23, 2004 | 03:06 PM
I think a racetronix fuel pump is in order for it. I didnt check to see if the fuel is dropping off but both 02 readings are 0.95 when at 100% ... I will call PCM4LESS tonight and see if he could up the pressure... thanks OBE1... anyone else??
Old Mar 23, 2004 | 10:21 PM
ledfootz28's Avatar
told u it could be the fuel pump :P
Old Mar 24, 2004 | 11:15 AM
Hey thanks for the help bud lol
PS - I still got your front Hals and DMS springs
TitoPR221
May 26, 2015 12:20 AM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
maybe2fast
Mar 13, 2015 11:48 AM
