383 review, ples help
Old Mar 16, 2004 | 06:50 PM
  #16
Serene's Avatar
Originally posted by LilJayV10
Why are you running a 4.125 head gasket with a 4.030 bore? I did that once on my olds 350, used the wrong head gaskets, filled the engine up with water the first time i started it and ruined it.
I gotta be missing something here.
Jason
People jeez. Head gaskets are not exactly the same size as the bore. Your problem came cause you used the wrong gasket.
Old Mar 16, 2004 | 06:59 PM
  #17
OpCode's Avatar
Fel Pro 1074:
Chevrolet: 1992-96 5.7L (LTI and LT4 engines only), .039 in. compressed thickness, 4.125 in. gasket bore, 8.7cc compressed volume, head gasket
Old Mar 16, 2004 | 08:35 PM
  #18
Juiced Impala SS's Avatar
I have about 11.4 CR and use the crappy 91 octane gas here in CA. As long as you keep the timing on the safe side, you should be fine.
As for the 220's, better hope you have A LOT of cam to take advantage of those ports.
Bottom end sounds just like mine. Just make sure the machining and assembly is top notch and you won't be disappointed.
Old Mar 16, 2004 | 11:34 PM
  #19
LilJayV10's Avatar
Jeeeeez. Sorry. Yeah no ****, I used the wrong gasket.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
tommalcolm
Sep 11, 2015 03:39 PM
alphaauto
Jul 26, 2015 04:40 PM
