383 re-tune
Old Jun 5, 2004 | 01:32 PM
Briank8811's Avatar
383 re-tune
Is it essential to have my PCM re-tuned for the 383 stroker and mods i have below? Will it be ok or will it run like shat?
Old Jun 5, 2004 | 01:57 PM
Toker420's Avatar
i think that cam is going to be pretty tame since the more cubes the bigger the duration so by you boostin the cubes you weakened the cam. with that little of a cam it might run but you need to get it tuned pcmforless.com.
Old Jun 5, 2004 | 02:08 PM
Max 93's Avatar
I would atleast have it programed so that the PCM knows it's a 383 and not a 350, if you have differant injectors I would change that too. You probably don't need to change anything else.
Old Jun 5, 2004 | 05:24 PM
gb95zconv's Avatar
If you want to get the most out of it you need to get a baseline tune for a hotcam and then dyno tune to get your WOT numbers dialed in.......otherwise you could be leaving 20-40 hp untapped. It simply makes no sense to spend the money on a 383 and scimp on the tuning.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
