383 re-tune
i think that cam is going to be pretty tame since the more cubes the bigger the duration so by you boostin the cubes you weakened the cam. with that little of a cam it might run but you need to get it tuned pcmforless.com.
If you want to get the most out of it you need to get a baseline tune for a hotcam and then dyno tune to get your WOT numbers dialed in.......otherwise you could be leaving 20-40 hp untapped. It simply makes no sense to spend the money on a 383 and scimp on the tuning.
