383 Oil Pan Clearance
Old Feb 18, 2006 | 11:26 AM
3gc's Avatar
3gc
Does anyone have a picture of how they clearanced their oil pan for a 383. Did you also have to clearance the oil pan gasket? I see where the block had to be clearanced for the rods, is that where the oil pan should be clearance. How did you go about clearancing? The oil pan seems way to thin to grind and if i use a hammer and dent it, it seems like the rail will get bent and I'd end up with an oil leak.
Old Feb 18, 2006 | 12:29 PM
calfirebird's Avatar
Re: 383 Oil Pan Clearance
i just put some playdoe on the pan and spun the motor and saw where it was hitting and then used a BFH to clearance the pan.
Old Feb 18, 2006 | 12:46 PM
3gc's Avatar
3gc
Ok thanks. Dosn't sound too hard. I'll figure it out when i go out there and test fit it.
Old Feb 18, 2006 | 02:34 PM
firebirdStud's Avatar
with my 383 I didn't have to touch the pan. The problem was the windage tray that bolts to the crank bots. There is your problem. But, feedback that I am getting is that I need a better aftermarket pan. Check out my post, Which oil pan. Might be of help.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
