383 lt1 le2 bret custom cam
Old Apr 7, 2008 | 11:56 AM
kline454's Avatar
what kind of h.p should i make at the fly wheel? :
Old Apr 7, 2008 | 11:58 AM
mdacton's Avatar
cam only?
if you make 450 you would be in an elite few.......
More like cam only....375 or so at the flywheel.
I have seen alot of his cam specs online now...so I plan to copy them and start my own line of cams called Bert Browers......made in china
Old Apr 7, 2008 | 12:04 PM
kline454's Avatar
Originally Posted by mdacton
cam only?
ok thats cool
Old Apr 7, 2008 | 12:06 PM
mdacton's Avatar
Originally Posted by kline454
um no its a 383 le2 heads le ported intake bret custom grind cam,58mm tb,36pound injectors,1.6 promags,1 3/4 long tube headers elc water pump,exc.
well you didn't specify...if your chasing dyno numbers I'm sure you can get 430 or so rwhp.....maybe 525 or so crank
Old Apr 7, 2008 | 12:09 PM
kline454's Avatar
ok thanks
Old Apr 7, 2008 | 12:24 PM
wrd1972's Avatar
cam only?
Old Apr 7, 2008 | 12:27 PM
SlowButSure94Z's Avatar
LMAO!!
I don't care who you are, that was funny...
Old Apr 7, 2008 | 12:36 PM
wrd1972's Avatar
Will you grind me a cam with parallel rising and closing ramps and vtec lobes?
RRRRRRRRight.
Old Apr 7, 2008 | 02:06 PM
T/A lt1's Avatar
It depends on alot of factors for making big horsepower but you should make 500+fwhp with a 10.1+ compression 383 as long as everything is right. Tuning is a big part and there is also good exhaust, no knock retard, fuel system, making sure everything is just right. I made 412rwhp thru a loose converter/ Th350 setup with my 355" Lt1. Now I am building a 383 to see what kind of horsepower we can make with Lloyds head cam setup. Later Clint
Old Apr 7, 2008 | 03:51 PM
roadtrip120's Avatar
Here ya go, one of my builds , for a friend of mine.
http://web.camaross.com/forums/showt...hlight=le2+383
Old Apr 7, 2008 | 06:48 PM
flyinZ's Avatar
I hope to post some #'s of my own, the first week in May..heads are similar to LE2 #'s, and the cam is a 242* .610* on a 108*.. Never got any track times, b/c I always change something b4, or after I go,lol.
LeftoverChinese
Jan 14, 2024 03:03 PM
mikey4play
Mar 15, 2015 11:45 AM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
super83Z
Jul 11, 2002 10:16 PM
