383 low compression pistons?
Old May 5, 2008 | 08:58 PM
red94chicken's Avatar
i can't find any reasonably priced .040 over 383 pistons with a 5.7 inch rod.. anyone know of a source?
Old May 6, 2008 | 05:34 AM
Guest47904's Avatar
Guest
There's 5 pages of them at Summit. Learn how to use the "departments".
(x) Remove Department: Engines & Components
(x) Remove Section: Pistons & Piston Rings
(x) Remove Part Type: Pistons
(x) Remove Bore (in): 4.040 in.
(x) Remove Rod Length: 5.700 in.
(x) Remove Stroke: 3.750 in.
ETC ETC ETC.......
Old May 6, 2008 | 05:37 AM
rskrause's Avatar
Moderator
There must be eleventy billion people making Gen I SBC pistons. Are you trying to find pistons specifically designated for the LT1? That may be the problem. They are the same as for any other Gen I motor.
Are you looking for a stock replacement or a forged performance piston?
Rich
Old May 6, 2008 | 05:51 AM
NVetro's Avatar
I had to get a set of custom forged pistons from JE to get the compression I was looking for, they don't make an off the shelf piston with the specs I wanted....They can be expensive, like $1000, but give it a shot, they will build to order.
Old May 6, 2008 | 05:54 AM
rskrause's Avatar
Moderator
Just curious, but why a low CR ratio if you aren't running a blower?
Rich
Old May 9, 2008 | 09:22 PM
i am looking for a forged.. keith blacks are the only thing that comes up and i don't know how great of a piston they will be for what i want to do..
Old May 10, 2008 | 09:34 AM
NVetro's Avatar
rskrause: Currently the CR for the motor is 10.9:1 with those pistons and 54cc lt1 heads.......it is a nitrous motor for now, but in the future I want the option of slapping on a set of larger cc heads to drop the CR down and put a blower and nitrous on it without having to rebuild the bottom end to acompdate a blower....Just planning for the future
Old May 10, 2008 | 10:03 AM
quickSS's Avatar
Mahle has a -26cc inverted dome piston but yea that lowers compression ratio a bit too much.
Mahle part number SBC425040I26
Summit: http://store.summitracing.com/partde...0&autoview=sku
The SRP -16cc D-dish piston looks good. That's for a 383 stroker (3.75") and 5.7" rod (1.425" compression height) and it's for a 4.040" bore.
#139629 http://store.summitracing.com/partde...0&autoview=sku $560 at summit but then you have to buy the piston rings which would be about $100 more.
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
IDOXLR8
Aug 6, 2002 12:30 PM
