383 a/i lt1
Old Jun 28, 2010 | 02:14 PM
  #16
Yates's Avatar
Originally Posted by Nostang 96z
Pull the opti and check the rotor and optical sensor. It is worth a try. My car acted the same way right before my rotor destroyed the opti.
should there be obvious damage if it's bad or will i need to swap optis to be able to tell?
thanks
Old Jun 28, 2010 | 02:30 PM
  #17
hsyr's Avatar
Maybe its the NGK 8s giving you the problem? What are they gapped at? I had a similar problem and it turned out to be the brand new plug wires I installed (they were garbage).
Throwing $ at the car sucks but I would try a new set of Taylor OTV wires and some NGK TR6 plugs gapped at .035 .
Old Jun 28, 2010 | 03:45 PM
  #18
If the optical sensor was causing problems, there would be trouble codes stored. One exception would be erratic readings from the high resolution part of the sensor - if that is erratic, the tach will start to jump around, and it may screw up the timing. As long as there's a signal, the code may not set, even if its an erratic signal.
If the high voltage section is causing the problems, there would not be any codes. But you may see the rotor loose, the rotor being pushed forward and grinding on the cap, or rubbing on the divider between the front and rear sections of the Opti, damaged contact buttons, carbon tracking, burned contacts/rotor. Check the Opti harness connector as well, for corrosion, damaged pins, or a missing clip that hold the harness on the Opti.
Old Jun 30, 2010 | 09:41 PM
  #19
Yates's Avatar
ngk 8s i think are gapped at .040. i just swapped into the origional delcos. seems to smooth things out a little but still pops out of the intake when it warms up. my wires are also new...they are msd super conductor 8.5s. think this could be an issue?
Old Jun 30, 2010 | 09:44 PM
  #20
Yates's Avatar
well i've been putting it off but.....i guess i'm gonna have to pull the opti and give it a look. i haven't seen the tach do anything crazy though.
cheapchevy
Apr 8, 2015 08:48 PM
cristian1311
Nov 23, 2014 02:22 PM
Queens94z28
Nov 20, 2014 06:03 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
