383 head gasket problems with nitrous
Old May 12, 2008 | 10:28 AM
  #16
96capricemgr's Avatar
I would think hardness would show up under power as a sudden loss of sealing of the gasket. Weeping IMO points towards bad machine work in flatness or finish on one or both of the mating parts.
When you say cylinders 7-8 you are saying the rearmost cylinders on BOTH sides right??
Old May 12, 2008 | 12:20 PM
  #17
kline454's Avatar
yea the rear cyl. on both sides it looks as if when the block was zero decked they didnt do a very good cut and left small marks for the compression to leak out..
Old May 12, 2008 | 01:34 PM
  #18
TitoPR221's Avatar
Originally Posted by kline454
Well i started out last year with the felpro 9966pt and after about a month the head gaskets started to leak on cly. 7-8 then i went to the 1074 head gaskets ran them all year no problems now i went with le2 heads and the MRG-5716 gaskets and now there leaking on cly. 7-8, i was thinking about going with the 1074 gaskets but would lose compression so im looking at http://store.summitracing.com/partde...T&autoview=sku has anyone tryed these??
Another item to consider: Did you deck the block? The factory deck flatness and surface finish are unreliable at best. You got new heads that are certainly "true" with polished surfaces. If the deck is not true and the surface finish is not as per gasket manufacturer requirements, then the gaskets are bound to fail under the higher stress.
Old May 12, 2008 | 01:49 PM
  #19
kline454's Avatar
well im just going back with what i know works and never had any problems with the 1074gaskets.
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
