383 guys!!! Need advice
Old Sep 15, 2003 | 07:10 PM
flyinZ's Avatar
Im havin a little trouble finding my powerband...I have a 383 with a CC 306, 2.00/1.56 valves,p/p heads,3200 Midwest (2.5 str), and 3:73's...Any ideas??? my shift points are 1-2 6200, 2-3 6400, and my redline is 6700 rpm...Anymore questions, let me know.
Old Sep 15, 2003 | 07:22 PM
Juiced Impala SS's Avatar
CC306 likes to spin... so with that, your shift points are too low. I'd say shift somewhere around 6500-6700. Only a dyno will tell you for sure. Shift 200-300 AFTER peak HP My cam (see sig) peaks at 6200 and I shift at 6400 and it's a small cam than the 306.
Old Sep 15, 2003 | 07:34 PM
TreySpeed's Avatar
On permanent vacation
what year t-56?
or is it an auto?
Old Sep 15, 2003 | 07:39 PM
94formulabz's Avatar
I think he's got an auto, but yeah what juiced said. Stock head guys are shifting a lot higher than that, like 6800
-brent
Old Sep 15, 2003 | 07:42 PM
flyinZ's Avatar
Its a 94'z, A/4, 3200 Midwest Torque Converter (2.5 str)
Old Sep 15, 2003 | 07:47 PM
TreySpeed's Avatar
all your shift points, whereever they may be should be (about) the same. If anything, first gear should pull longer, not shorter
gear ratios:
3.06:1
1.62:1
1:1
3.06/1.62= 1.88
1.62/1.00= 1.62
Old Sep 16, 2003 | 07:03 PM
flyinZ's Avatar
Anybody else?
Old Sep 16, 2003 | 07:52 PM
BES-383's Avatar
My 383 was still pulling 532 fwhp at 7400 rpm. You need to dyno your car too see exactly what your shift points should be.
Old Sep 16, 2003 | 08:04 PM
96z's Avatar
96z
You should set your shift points 200 rpm past peak power with your A4. Also both the shift RPM and shift MPH need to be meet for the tranny to shift at WOT.
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
cmyname1
Feb 16, 2015 08:33 PM
1775.Z28
Jan 11, 2015 10:51 AM
Red97LT1
Aug 7, 2002 05:45 PM
