383 guys!!! Need advice
Im havin a little trouble finding my powerband...I have a 383 with a CC 306, 2.00/1.56 valves,p/p heads,3200 Midwest (2.5 str), and 3:73's...Any ideas??? my shift points are 1-2 6200, 2-3 6400, and my redline is 6700 rpm...Anymore questions, let me know.
CC306 likes to spin... so with that, your shift points are too low. I'd say shift somewhere around 6500-6700. Only a dyno will tell you for sure. Shift 200-300 AFTER peak HP My cam (see sig) peaks at 6200 and I shift at 6400 and it's a small cam than the 306.
all your shift points, whereever they may be should be (about) the same. If anything, first gear should pull longer, not shorter
gear ratios:
3.06:1
1.62:1
1:1
3.06/1.62= 1.88
1.62/1.00= 1.62
gear ratios:
3.06:1
1.62:1
1:1
3.06/1.62= 1.88
1.62/1.00= 1.62
