383 dyno #'s
Old Sep 13, 2005 | 08:25 PM
rob97ss's Avatar
383 dyno #'s
First time on the dyno 365rwhp-370rwtq.mildly ported lt-4 heads,xe 230-236,stock tb,stock injectors,slp shorties.I'm sure if i upgrade the stock parts it will squeeze a few more out.
Old Sep 13, 2005 | 08:28 PM
Kreinmc's Avatar
Re: 383 dyno #'s
Those numbers are way low. Get rid of that cam for a proven cam and put some LT's on that thing.
Old Sep 14, 2005 | 09:37 AM
Admiral94's Avatar
Re: 383 dyno #'s
You may want to upgrade your injectors as well.
Old Sep 14, 2005 | 09:59 AM
CANTONRACER's Avatar
Re: 383 dyno #'s
Before you go swapping every part because it seems the easy thing to do...
Stock injectors can easily support cars going 115 mph in the 1/4.
It was your first time @ the dyno...how was your AFR...timing...tuning?
That cam is a good cam.
You can easily squeeze 400 rwhp/400rwtq with the parts you have if you are willing to work on it.
Old Sep 14, 2005 | 10:46 AM
N20Dave's Avatar
Re: 383 dyno #'s
I agree with Canton, the combination of parts is good and there's nothing wrong with that cam. I had that cam in a 355 LT1 with stock heads and a P600B that made 536 at the wheels.
As mentioned, look at items like AFR. If it were me, I probably would go with a bigger throttle body and long tube headers. Try to narrow in on the tuning first.
IEAT50Z's Avatar
Re: 383 dyno #'s
aren't stock injectors maxed out at 350RWHP?
Old Sep 14, 2005 | 11:04 AM
Victory Racing's Avatar
Re: 383 dyno #'s
More information on the heads please. Valve size, flow numbers?
Camshaft should do the job, larger TB is more neccasary than the larger injectors but I would do both.
Old Sep 14, 2005 | 11:52 AM
T/A lt1's Avatar
Re: 383 dyno #'s
It's not the injectors it's the tuning or lack there of. My car ran 11.24@120mph with the stock injectors and a decent tune. I went from running 11.98@113mph to 11.37@118mph on the very next pass with just a PCM reprogram at the track. Longtubes, good exhaust (headers back) and a bigger throttle body wouldn't hurt either. With LT4 heads that cam and a 383 you should be making more power than that. Goodluck Later Clint
Old Sep 14, 2005 | 05:25 PM
rob97ss's Avatar
Re: 383 dyno #'s
Thanks guys,i agree i dont think he put much effort into the tune,he did two pulls,including the baseline pull.i dont have a flow sheet ,but they flow close too 270cfm,2.00int-1.55ex valves. the car runs and sounds great,im sure with more tuning,lt's,tb it should get a little more out of it.
Old Sep 14, 2005 | 05:33 PM
'94 Bad A Z28's Avatar
Re: 383 dyno #'s
My car trapped 116mph on the stock injectors.
fift5
11
Oct 1, 2015 10:31 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
