383 cam???? Need help!!!
Old May 8, 2006 | 12:33 AM
LUDA0840's Avatar
Ok I got a cc306 in there, but I dont want to spin the engine so high. Whats another off the shelf cam that would make good power, and wont have to spin the engine so high? Is a 218/218 .544 .544 cam to small?
Old May 8, 2006 | 02:07 AM
sssalah's Avatar
Re: 383 cam???? Need help!!!
A cc306 isn't big for a 383, but if you want to go small for emission and better driveability then you have the cc503. Watch your DCR beffore baying the cam.
Old May 8, 2006 | 04:33 PM
WS Sick's Avatar
Remember that in a 383 with decent compression that cam will act like it has about 10 to 12 degrees less of duration. I had a 224/230 XE in my 10:1 comp 383 when I first put it together and it had only a slight thump to the exhaust. It also peaked below 6000 rpm. I now have the GM847 and it thumps quite better and revs very smoothly to 7000 rpm (by the factory tach).
I wouldnt go smaller than the CC305 or the GM 846 range.
Old May 8, 2006 | 05:37 PM
LUDA0840's Avatar
my 383 is 12:1 compression
Old May 9, 2006 | 12:33 AM
sssalah's Avatar
That's a lot of compression to run a small cam, if anything you should get a bigger cam. The cc468 is a good cam for your motor, it will idle similar to the cc306.
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
