cam question
Old May 8, 2006 | 07:02 PM
net_coma's Avatar
cam question
Is this the cc503 cam and do I have a concern with use with the 96 vented opti spark? I read today that there is a cam difference with the vented opti spark in the pin length and maybe another hole or other difference on the forward end.
Comp Cam #07-503-8
Specs: LT1 (xr276hr-12)
ADV 276 281
DVR@.50 224 230
LIFT .503 .510
Old May 8, 2006 | 09:50 PM
OrbitalChris's Avatar
Re: cam question
yep thats it, and you should be fine with the length, but give thunder racing a call theyll help you out
good luck man!
Old May 8, 2006 | 10:27 PM
net_coma's Avatar
Re: cam question
Thanks, thought so but wanted a second opinion.
Old May 8, 2006 | 10:56 PM
Re: cam question
Always make sure the dowel pin is the correct length.
Old May 9, 2006 | 02:00 AM
sssalah's Avatar
Re: cam question
The pin should be 0.615-0.620" long.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
