383 burning oil
Old Mar 18, 2008 | 09:21 AM
kline454's Avatar
383 burning oil
383 burning oil after head porting, i had a very well know lt1 head porter do my heads and now im using oil used 1qt in 150miles and there are no leaks so it has to be burning the oil, Motor has 6000miles on it. And last year never used any oil i checked compression 205-210psi on all 8.
Old Mar 18, 2008 | 11:08 AM
BlackScreaminMachine's Avatar
Sounds like the valve seals are fragged.
Old Mar 18, 2008 | 01:37 PM
gatorhead's Avatar
Could be seals or guides. When I first saw 383 the usual suspect of pin height up in the ring lands.
Old Mar 18, 2008 | 01:51 PM
kline454's Avatar
well the only other thing is i had a nitrous backfire the other day but i think it was using the oil before that. but i could be wrong.
Old Mar 18, 2008 | 02:55 PM
Do a leakdown test. That will tell you.
Old Mar 18, 2008 | 03:52 PM
Dave89IROC's Avatar
might also be sucking oil into the intake runners via the rocker stud holes, common w/ ported heads
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
TitoPR221
May 26, 2015 12:20 AM
surreybrad
Apr 22, 2015 06:40 AM
