383 Build
Old May 12, 2008 | 01:15 PM
  #16
TitoPR221's Avatar
Originally Posted by slomarao
are you building the motor or buying a complete shortblock?
If you are asking me (TitoPR221), I took my block to my preferred machine shop for boring and decking, then I installed the rotating assembly. I received the heads this week. Next weekend I'll degree the cam and install the heads and measure the push rod to get the proper push rod length. By then I should have received the rest of the parts to put the engine together. It's a process, lots of patience and planning needed if you are doing it yourself, but it's more fun.
Old May 12, 2008 | 06:31 PM
  #17
RallyBoy1's Avatar
Originally Posted by Dave1980
sounds like it will be hard to stay within budget with only 6k with a forged bottom. (all of the extras will add on top of the mix.)
Yep, I am in the same boat that you are. After adding everything up, I am looking at $7500-$8000.
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
