Whats my DC
Old May 3, 2008 | 10:46 PM
Chevyguy358's Avatar
Whats my DC
I have a motor that I am interested to see if its DC is too high I have a feeling that it might be. here are its specs
383
4.03 bore
3.75 stroke
5.7 in rods
flat top pistons -5cc valve refliefs
54cc heads
cam: 230/236 112 LSA 107 center .544/.554
.039 head gasket
dont know piston to deck or quench
Old May 4, 2008 | 09:56 AM
FryedClutch's Avatar
here is a pretty cool site you will learn alot from
plus you can download a killer calculator
http://www.empirenet.com/pkelley2/DynamicCR.html
Old May 4, 2008 | 10:32 AM
TitoPR221's Avatar
To calculate the DCR, you need the intake ATDC max lift timing. To calculate both the static and dynamic CR's you need the deck height and the gasket bore. Do you have access to the machine shop that prepped the block? They should have all the block info you need. The ATDC intake data is in the cam spec card.
Old May 4, 2008 | 12:03 PM
its Zero deck hieght and the gasket bore is 4.04
Old May 4, 2008 | 12:04 PM
Yea I've already been there and downloaded the calc i must be filling out one of the fields incorrectly as I got a 11:1 DCR
Old May 4, 2008 | 03:13 PM
jasonisdn's Avatar
Notice the post by Tito, he's dead on. You have to have the atdc number and 11.1 is to high for DC.
Old May 4, 2008 | 03:40 PM
rskrause's Avatar
Moderator
You need "advertised" duration, not duration at 0.050" to calculate DCR.
Rich
Old May 4, 2008 | 07:35 PM
the ATDC spec is 26
Old May 4, 2008 | 07:36 PM
Rich
advertised is 282/288
Old May 5, 2008 | 09:01 AM
anyone...
Old May 5, 2008 | 09:07 AM
rskrause's Avatar
Moderator
I calculate your intake closing point as 68 degress ABDC. Your DCR is 9.86. Your SCR is 12.67. I think you are going too far for pump gas. You need a thicker gasket or a bigger cam to bleed off some cylinder pressure. A bigger cam will help with detonation at low enegine speed, but you still may have a problem at or around peak torque.
Rich
Old May 5, 2008 | 01:18 PM
TitoPR221's Avatar
Correction: intake ABDC max lift timing.
Old May 5, 2008 | 01:55 PM
alright heres what i got down the list and the only thing im not sure of is the piston to deck clearance
bore 4.03
stroke 3.75
rods 5.75
cc chamber 54
head gasket .039
gasket bor 4.04
flat top pistons -5 cc relief
Cam:
282/288
lsa 112 center 106
IVO (BTDC) 35
evo(BBDC) 82
IVC(ABDC) 67
EVC (ATDC) 26
I keep getting reall high numbers
Old May 6, 2008 | 10:06 AM
TitoPR221's Avatar
bore 4.03
stroke 3.75
rods 5.75
cc chamber 54
head gasket .039
gasket bor 4.04
Cam:
282/288
lsa 112 center 106
IVO (BTDC) 35
evo(BBDC) 82
IVC(ABDC) 67
EVC (ATDC) 26
With the above numbers and zero deck piston height I get 12.38 Static CR and 9.72 DCR.
Old May 6, 2008 | 11:58 AM
rskrause's Avatar
Moderator
I posted the correct numbers. They are too high for pump gas.
Rich
