383 A4 Est.430 Rwhp
Old Feb 11, 2006 | 08:55 AM
playa7970's Avatar
383 A4 Est.430 Rwhp
This is what im estamating with the 383 im recieving shorty, what would i have to do to get my 4L60E to harrness that amount of power and say i have a 150 shot on top of that some info would be great because i had some bad experiences if ya know what i mean
Old Feb 11, 2006 | 01:19 PM
5.7LT1Formula's Avatar
Re: 383 A4 Est.430 Rwhp
I was looking for my build sheet but i could not find it, but some of the things you want to have include:
stock vette converter works great
Harden' imput shaft
Shift kit
extra clutch packs
dule race sprag
tri-planatary gears
corvette Servo
i believe there is a type of piston in the trans and they make a alum. or steel that is more heavy duty.
the biggest boost valve they make .390? .460? (can't remember size)
(the shift into 2nd is so hard the tires chirp every time around 20-30mph if it is a little bit wet you are sideways, i've broke them loose when it shifts from 2nd to 3rd as well) a good hard shift will help prevent slipping.
using all kevlar clutches and bands will take the heat alot better
a good tranny cooler
deep well trans pan w/ drain plug
after breaking in the trans adding some royal purple if you can afford it will also help it run cooler and reduce wear.
Old Feb 11, 2006 | 01:39 PM
playa7970's Avatar
Thanks for the reply how much is this gonna set me back?
Old Feb 11, 2006 | 02:23 PM
Honda Hunter's Avatar
Check out the vendors. I'm going to go with Dana most likely.
Old Feb 12, 2006 | 01:35 PM
i have 1700.00 in mine and i installed it myself to save on labor. that included a 12,000 mile / 12 month warranty.
Old Feb 12, 2006 | 02:24 PM
12SCNDZ's Avatar
www.cahallperformancetransmissions.com. Check out our "Pro Race" rebuild. It will safely handle what you plan on throwing at it, for $1400.
Thanks,
Frank Cahall
CPT
Old Feb 12, 2006 | 06:08 PM
1racerdude's Avatar
Send it to Rossler about 3 grand,or SR-7 Performance about 2500.
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
cristian1311
Sep 12, 2015 08:16 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
