383 and 396 Stroker Prerequisite
Old Sep 5, 2003 | 07:55 AM
BlueCamaroZ28's Avatar
Smile 383 and 396 Stroker Prerequisite
With so many companies recommending different fuel pumps, fuel injectors, Throttle Body sizes and camshafts for their stroker kits, I would like to know, from someone who had the 383 and 396 stroker kits installed to his Z28 LT1, what is the best setup of fuel system, TB size and camshaft to work with the 383 and 396 stroker for street/race driving.
Is the 52 mm BBK Throttle body good for the 383 if not good for the 396 stroker.
My 1994 355 Z28 LT1 is running TPiS ZZ-9 cam and LT1 ported heads. Stock injectors and ECU programming by Thunder Racing.
Old Sep 5, 2003 | 08:05 AM
Running 4L60E with Transgo shift kit, stock converter.
Old Sep 5, 2003 | 08:41 AM
MEAN LT1's Avatar
Re: 383 and 396 Stroker Prerequisite
The question asked is way to broad. Different setups require different needs. A forced induction setup will differ substancially than a setup meant for n/a. Narrow it down some
Old Sep 5, 2003 | 08:48 AM
playaz28's Avatar
Ok let me throw this into the mix and hopefully it will be able to help.
Me, in the future, I would like to do a stroker setup with the future of addition of turbocharging or supercharging my car with a small shot to get me off the line nicely.
What would be a good list of components or a good idea of where I should start to look at building first?
Old Sep 5, 2003 | 10:52 AM
playaz28's Avatar
Originally posted by aggiez28
well since you ask these kind of questions ill bet your relatively new to this kinda thing....... the best thing you could do is hang around her eread stuff and ask questions for 3-6 months maby more.... learn more about these topics and stuff.... it can save alot of headaches in the long run... lets say you jump into somthign now.. a year down the road when you have learned alot more you may say damn i wish i had done this or this differently.
brook
was that in response to me or the original thread starter? if it was to me, I have been here for a little while and I do know more than my fair share (or at least I'd like to think so ) I should have specified a little more, my questions really would be regarding what types of compounds would I want the materials to be. I would assume forged since I plan on boosting, but maybe the lighter weight 5140 material would be better. Also fuel delivery, would I need to go with a whole new setup or just add a larger fuel pump, injectors, etc...
And if that wasn't in response to me, oops.
Old Sep 5, 2003 | 01:50 PM
Smile
Let me put it clear for fellows who share us positive responses. I am not worried about material selection. I intend to build a NA engine. I may in future spray 100 or 150 NOS. So, forged pistons will be my choice.
What I am after is fuel delivery, ECU programming and if any of my current mods, see my signature, should be upgraded. There is no shame to ask questions if someone does not know and this is why we are all here to exchange good ideas and thoughts.
I have noticed different schools in building stroker engines. Some upgrade the fuel injectors and some just reprogram the ECU and upgrade the fuel pump to force the stock injectors into supplying the extra fuel needed by the bigger stroker engine.
For each one there are pros and cons. I would like others to share their actual experience. I don't mind to hear thoughts and ideas, too.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
alphaauto
Jul 26, 2015 04:40 PM
