383/396 guys inside, post your NUMBERS
Old Jun 29, 2004 | 09:49 PM
Schurters LT1's Avatar
I am looking into doing a stocker eng in the furture and would like to see the diff combos that are out there,
What you have done to the short block, ie:rods,crank,pistions,ring, bearings,oil pump ,oil pain
Top end ie: heads,cam,intake
What RPM are you turing.....any and more info would be great.
thx
Old Jun 29, 2004 | 09:59 PM
Dave88LX's Avatar
#'s don't matter, it's who gets to the finish line FIRST
Old Jun 29, 2004 | 11:14 PM
1982z28with18s's Avatar
This is actually a good point. Peak #'s mean nothing, its the curve that you need and the rest of the combination. But anyway, back to the thread now.
Old Jun 29, 2004 | 11:18 PM
1racerdude's Avatar
Dave--Ya got that right--HEE HEE
Old Jun 29, 2004 | 11:24 PM
ninetythreez's Avatar
Maybe he meant 'part #s' of the guts of the motor.
Old Jun 30, 2004 | 05:11 AM
Dave88LX's Avatar
Re: .
Well...in that case I can help out with that too
This is the latest one, need to update a few parts:
http://paradox.shacknet.nu/dave88lx/formula/383/383.htm
Depending on the year of your car some parts may be different. (Gaskets & seals)
Old Jun 30, 2004 | 12:05 PM
SS MPSTR's Avatar
Nice spreadsheet and information, Dave. Your list represents the 'reality' of all the little things that tend to add up fast. Throwing a lot of parts at that car at once. Should run great, and it looks like you did your homework.
Didn't see the valvesprings accounted for though? Probably in another line item.
Old Jun 30, 2004 | 12:15 PM
zhevy-1's Avatar
383 stroker. AFR 190cc heads, 6" rods, bored .040 over, so it's actually a 386 rather, or close to it. Dimond pistons, milled heads, and ported intake, 285cfm at .550 288 @~.600
Dynoed 396.6 @ 6050rpm and 396fptq @ 4900rpm on a Mustang Dyno, or about 420rwhp on a dyno jet.
Custom ground cam.
Old Jun 30, 2004 | 12:17 PM
Dave88LX's Avatar
Thanks man, I learned this game can dollar you to death!
It's easy to say "Aww, crank, rods, pistons and I'm set, but the reality of it is once you jump in, you start going overboard, you need support equipment, you decide you want to do things a little different, do things the right way", and it adds up quick!
I don't really have the valvetrain stuff up there, I haven't updated it since I talked to Phil last, but I'm running Comp 977 springs and Titanium retainers
I'll have to update that list, thanks for making me get on it.
Old Jun 30, 2004 | 12:55 PM
Gripenfelter's Avatar
383.
LE2 cam
LE2 heads
Scat crank
SRP pistons
Eagle H rods
426rwhp...still tuning.
Old Jun 30, 2004 | 01:11 PM
944v8inDFW's Avatar
Gripenfelter Can you remove GAIN
Could you please remove GAIN installer from your homepage. IMO worst piece of adware / spyware out there. Looks like you got a nice page but GAIN made me run like the wind.
Old Jun 30, 2004 | 02:13 PM
ZBLKHELLRZR's Avatar
4 bolt main bored .040 over, Lunati Forged rods 5.85, Ross custom pistons, Total seal gabless rings, Fed mogul coated bearings, melling high volume oil pump, milled LT1 heads 2.00/1.56 flow close to 280cfm, ported intake, hydra rev kit, custom grind cam 23X/24X 110 LSA, 1.6 RR, 941 springs, comp R lifters, chrome moly pushrods, AS&M 58mm TB, 30# inj, 255 walbro pump, canton race fuel filter, no numbers but I trap on a street tire around 117-118mph 1300 elevation on a 3.23 M6 M29 tranny.
Old Jun 30, 2004 | 02:27 PM
Sorry about Gain. No way to remove it. Its part of Fortunecity.com
You don't need to install Gain and you shouldn't! lol
Just click cancel.
Ignore the dyno video on the page. Thats crank hp from a previous setup.
DirtyDaveW
Dec 1, 2016 05:37 PM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
Red97LT1
Aug 7, 2002 05:45 PM
