car studdering bad. need help
Old Jun 27, 2004 | 09:23 PM
94flamedta's Avatar
My car is missing really bad down low. It's fine past half throttle, and i have everything up top. But cruising between 2 and 3000 at constant throttle it'll miss really bad then take off and run fine, then miss really bad, then take off. What the hell is wrong? Any help would be great. I replaced the tps (not the problem) and changed the plugs (not the problem) Thanks again. I think i'm gonna try wires now and see what happens.
Old Jun 27, 2004 | 09:44 PM
DonHood's Avatar
Getting any check engine light at all? Sounds a lot like an oxygen sensor problem.
Old Jun 27, 2004 | 10:26 PM
n2ceptor's Avatar
check the MAP sensor..... If you search, ie " map sensor" you will see some threads with a familiar prob...
Old Jun 28, 2004 | 04:07 PM
94flamedta's Avatar
I'll check that. thanks. the ses light does come on but only when it runs fine. When it begins to miss the light then goes off. go figure.
Old Jun 28, 2004 | 04:09 PM
Cmr0z28's Avatar
It's the O2 sensors.
I had the same thing 2 months ago.
When the SES light comes on, the PCM goes into open loop, ignoring the O2 sensors, which is why it runs fine...then when it goes back to closed loop, it runs like an *** sandwich.
Old Jun 30, 2004 | 03:00 PM
94flamedta's Avatar
well i guess i'll give that a shot then. hopefully it works. any other ideas if it doesn't?
Red97LT1
9
Dec 17, 2014 06:13 PM
USAirman93
Nov 24, 2014 03:37 PM
CobraEatr
Jul 24, 2004 11:37 AM
CLEAR
Aug 30, 2002 07:49 PM
Zaddiction
Aug 2, 2002 10:12 AM
