383-396
Old Apr 19, 2005 | 11:41 AM
EVERESTZ28's Avatar
383-396
The diference betwen 383 and 396 is the bore? and the stroke is the same?
Old Apr 19, 2005 | 11:50 AM
Pasky's Avatar
Re: 383-396
bore is the same, stroke is different.
383 = 3.750 stroke
396 = 3.875 I believe
Old Apr 19, 2005 | 12:10 PM
guywithaZ's Avatar
Re: 383-396
not to hijack but is there big power diff in the 13 cubes...will I notice not getting building the 396...
Old Apr 19, 2005 | 12:47 PM
EVERESTZ28's Avatar
Re: 383-396
why apears to be more popular 383 than 396?
Old Apr 19, 2005 | 12:51 PM
Pasky's Avatar
Re: 383-396
The extra machine work involved in a 396 makes it not so popular.
Old Apr 19, 2005 | 12:54 PM
1racerdude's Avatar
Re: 383-396
13CI has never won a race. The differance in the machine work,if you dont go with an aftermarket block, is not worth it. You could go to a 406 or bigger for the same expense or trouble.
Old Apr 19, 2005 | 02:08 PM
EVERESTZ28's Avatar
Re: 383-396
so.....what is the most reliable 383 kit all forged?
Old Apr 19, 2005 | 02:11 PM
1racerdude's Avatar
Re: 383-396
Yes
Old Apr 19, 2005 | 02:15 PM
EVERESTZ28's Avatar
Re: 383-396
what brand do you recomend?
Old Apr 19, 2005 | 02:31 PM
guywithaZ's Avatar
Re: 383-396
Someone is on the same path of destruction I am...I too want to know this...
Old Apr 19, 2005 | 03:32 PM
ABA383's Avatar
Re: 383-396
I have a Callies crank, Oliver 5.85" billet steel rods, and JE pistons....This is the combo LPE used in my 383 and its been flawless since 1995...In fact, when I just freshened the motor I did a cam change and head freshen and just left the bottom end alone...It compression tested 205-220 in all 8 so I left it alone...If it ain't broke, don't fix it because you are going to break something else..(my motto..)
--Alan
Old Apr 19, 2005 | 05:26 PM
JustNO's Avatar
Re: 383-396
--Alan
Lunati Crank, Oliver Billet 6.00 Rods, Diamond pistons.. I like your Rods choice Its the BEST I think! And I guess its the most powerful rotating assembly.
Old Apr 19, 2005 | 05:34 PM
Mindgame's Avatar
Re: 383-396
Won't get much for "power" from a rotating assembly.
What you need is an assembly that will get the job done without breaking the bank. Then take the money you saved by NOT buying billet parts and put that into the heads, intake, camshaft, valvetrain.
Too many people waste money on stuff they don't need.
A few questions though....
Is this going to be NA or are you going to run a power adder?
What's your HP/TQ goal?
What's the budget?
-Mindgame
Old Apr 19, 2005 | 05:40 PM
JustNO's Avatar
Re: 383-396
What's the budget?
-Mindgame
My rotating assembly should handle +800 hp ,so for different situations good quality parts required.
Old Apr 19, 2005 | 05:52 PM
Mindgame's Avatar
Arrow Re: 383-396
Think we covered that.
Everyone's needs are different. Just important to know what you need in the first place.
-Mindgame
