383 or 355
Old Nov 2, 2005 | 08:17 PM
BadCamaro's Avatar
Lightbulb 383 or 355
My mods will be like this
Head
Cam 306
355 stroker
3.55 ratio
els..
No NOS
I hope to get 11.3-11.8 and daily driver
My question is which stroker gets me in this time and still daily driver
Old Nov 2, 2005 | 08:57 PM
rskrause's Avatar
Moderator
Re: 383 or 355
All else being equal, a stroker will be more drivable, if anything, than the same heads/cam/etc. in a stock stroke motor. I am not sure what you are getting at.
Rich
Old Nov 3, 2005 | 06:57 AM
calfirebird's Avatar
Re: 383 or 355
Well i think i might know what your asking. But a 355 isnt a stroked motor it is simply a 350 bored out. Either motor will give you the Hp to get into the 11s depending on other mods. 383 would be eaiser to make the hp and keep it streetable. Maybe i didnt Refrase the question please.
Old Nov 3, 2005 | 10:44 AM
DavesLT1's Avatar
Re: 383 or 355
I'm guessing the 3.55 ratio is your rear end? I thought those were Ford 9 inch gears. if you're putting a 9 inch rear into your car you'll probably want to go with the 383 to get extra power to push it. also I'd recomend the 3.89 gears if you can get some.
Old Nov 4, 2005 | 09:04 AM
BadCamaro's Avatar
Lightbulb Re: 383 or 355
Someone told me that there is 3.55 can be installed in the 10 bolt. And as you sed that 383 is eaiser to make the hp and streetable than 355. what is the cost for both 355 and 383 as a package?
Old Nov 4, 2005 | 09:16 AM
rskrause's Avatar
Moderator
Re: 383 or 355
Maybe you should post this in "Drivetrain". Since it's posted here, most people think you're asking about displacement, not rear end ratios.
Rich
Old Nov 4, 2005 | 06:54 PM
DavesLT1's Avatar
Re: 383 or 355
the 383 engine and 355 engine aren't too much different, the machine work is nearly the same as the block has to be bored and decked for both, and a new forged rotating assembly is only slightly more for the 383.
Old Nov 4, 2005 | 07:11 PM
FuryZ28's Avatar
Re: 383 or 355
If keeping it N/A, go stroked. If going blown, keep it 355.
Old Nov 4, 2005 | 07:12 PM
rock1501's Avatar
Re: 383 or 355
383 is the way to go but you will need a 12 bolt rear a big cam and some nice heads to run 11.3`s
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
