383 .20 or .30 over??
Old Aug 27, 2004 | 01:29 PM
Camaro_Guru16NY's Avatar
like it says
thanks,
-john
Old Aug 27, 2004 | 01:32 PM
zhevy-1's Avatar
Re: 383 .20 or .30 over??
0.30 to be a true 383, wouldn't it?
Old Aug 27, 2004 | 01:35 PM
Mindgame's Avatar
Have your machinist do the minimum it takes to get the bores true. Also check to see that you can get the pistons you want in that size off-the-shelf or are the going to be cu$tom order?
-Mindgame
Old Aug 27, 2004 | 02:24 PM
GreenDemon's Avatar
Agreed.
Plus .030 over is probably more common and will have more options available as far as parts are concerned.
Old Aug 27, 2004 | 02:51 PM
96speed's Avatar
-Mindgame
My block was already .030 over, but it needed a little more boring to clean it up. Don't get caught up in the numbers (38Xcid). Less material (larger bore) = earlier retirement .
Ryan
Old Aug 27, 2004 | 05:48 PM
CamaroRob97's Avatar
Certainly is....
4.030 x 4.030 x 3.75 x 8 x .7854= 382.6680858, obviously rounded up but yeah....
Old Aug 27, 2004 | 08:27 PM
SilverStreak's Avatar
Originally Posted by CamaroRob97
Certainly is....
Pretty smart for an eclipse owner.. just havin fun
Old Aug 27, 2004 | 08:48 PM
billy mensch's Avatar
if you can just go .20 over the more you bore the hotter it will run
Old Aug 27, 2004 | 11:52 PM
LameRandomName's Avatar
Frankly, if you were lucky enough to be able to go .010 over, you should do it.
I guess you could make an argument that if you don't plan on rebuilding again, going .030 over would give you the best range of options at the lowest cost, but I don't think the price difference or the option difference was as significant as it was 20 years ago, so I'm not sure that's something really worth worrying about anymore.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
