377 stroker build
Old Aug 17, 2006 | 04:31 PM
  #16
MEAN LT1's Avatar
Re: 377 stroker build
I hear what yall are saying about spinning the motor to 7k rpm but if you dont have to then why bother. RPM'S kill motors not horsepower, so if im able to achieve 550+ with in in that area then that would be great.
Old Aug 17, 2006 | 04:56 PM
  #17
joe-96z1le's Avatar
No need to spin a stroker motor that high. With the extra torque, he'll be making good HP at lower RPMs
Old Aug 17, 2006 | 06:00 PM
  #18
MEAN LT1's Avatar
exactly.
Old Aug 18, 2006 | 02:02 PM
  #19
Jerm93z28's Avatar
Originally Posted by streetrod93
7100 is very impressive for the stock pcm....i've seen some guys start sputtering a little as early as 6300
very impressive
thats where the tables end in a stock pcm. they should ALL go to at least 7,000 with tuning. sputtering at 6300 was other issues.
you dont HAVE to spin it up that high, but if the rpm range is available and you have nice stuff in the shortblock why not use it?
i will say that i have seen countless un-impressive 383's and other stroker motors.
Old Aug 18, 2006 | 02:28 PM
  #20
Ram Air 383's Avatar
Most problems that start at 6300-6500 rpms are valvetrain, not pcm, related.
Old Aug 18, 2006 | 03:15 PM
  #21
Jerm93z28's Avatar
or ignition..... or fuel......
Old Aug 18, 2006 | 03:25 PM
  #22
97WS6SCharged's Avatar
Ignition I could believe if the system wasn't up to the task. An opti would probably destroy itself above 7500 rpm. The fuel system would probably have more issues at idle than it would at high RPM.
Old Aug 18, 2006 | 03:46 PM
  #23
Jerm93z28's Avatar
a too small fuel system might idle fine, but may not keep up at high rpm.
Old Aug 18, 2006 | 04:14 PM
  #24
I was thinking more in terms of people using the stock PCM with large high impedence injectors. Some of them can't handle the low pulse widths needed for idle. Also, the large pumps will be constantly recirculating the fuel which will heat up. Shawn will need to replace the stock intank pump/booster combo he has before this thing is put together.
Old Aug 19, 2006 | 10:19 AM
  #25
MEAN LT1's Avatar
[QUOTE=Jerm93z28]
i will say that
Thats just like saying if you go to a buffet and you have a large stomach to put all the food in you should eat all the food.
I agree, which is why im going against the grain here with the next build. I see way to may 400-430hp lack luster stroker builds that i feel should be putting out more. Now Im not saying that those people whith in that range arent happy with there there cars as maybee that how they wanted them but Im after a bit more.
Old Aug 19, 2006 | 10:47 AM
  #26
Jerm93z28's Avatar
agreed. you can make that much with a stock shortblock.
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
