quick guideplate question!!
Old Aug 18, 2006 | 10:23 PM
94_camm's Avatar
If i get SA rocker arms do i need guideplates?and if i get NSA rocker arms do i need them?
Old Aug 18, 2006 | 10:30 PM
user 647483's Avatar
Re: quick guideplate question!!
NSA = Non-self-aligning ... Needs guides
SA = Self-aligning ... Does not need guides
Old Aug 19, 2006 | 09:31 AM
94_camm's Avatar
which one do you think is better to use on a high HP motor NSA OR SA??
Old Aug 19, 2006 | 09:54 AM
RE AND CHERYL's Avatar
The HP of the motor shouldn't make a difference. But if I were running valve spring pressures significantly higher than stock I would probably use guide plates.
P.S. Aftermarket guide plates never seem to line up right on the LTx motors. It's best to use the GMPP plates. They are cheap and available from your dealer.
Old Aug 19, 2006 | 10:56 AM
I agree, GMPP plates are awesome
You can probably get away with SA with a stock of mild cam
and stock or Lt4 springs. If you go with anything bigger, go NSA.
Agressive ramp rates and high spring pressures will break the little
tabs off SA rockers.
There are a few people around here who've learned that the hard way.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
Catmaigne
Dec 25, 2014 12:16 PM
