355 shortblock cost$$$$
Old Aug 27, 2010 | 08:17 PM
Jasonz28camaro's Avatar
im looking on doing a forged 355 how much will that run boring the motor and assembly of the short block only.
Old Aug 27, 2010 | 10:17 PM
brucer's Avatar
alot.
Old Aug 28, 2010 | 07:13 AM
bw_hunter's Avatar
This varies so much by area you'd be better off calling local machine shops and getting quotes...
Old Aug 28, 2010 | 07:48 AM
n2ceptor's Avatar
Quailty parts and labor, easily 1200+....
Old Aug 28, 2010 | 10:38 AM
sounds about right $$$. anyone know of any cheap but good machine shops around houston
Old Aug 28, 2010 | 01:50 PM
chevyrules85's Avatar
1200? depends what you mean by forged, you want everything forged? what kinda quality? im doing a similar setup, and ill have over 3k in it. a good crank is going to be at least 700. good pistons, another 700+. machine work, mine cost is 1100 for all machine work, but thats a decent price
Old Aug 28, 2010 | 01:56 PM
I want it to be strong enough to be able to handle forced induction later if I decide to do that. But idk what I'm planning so i'm not going to build it for forced induction just a strong compression motor.
Old Aug 28, 2010 | 03:59 PM
Larsv8's Avatar
I recently took my motor and had it rebuilt at a place called Harolds machine shop out towards Sugar Land.
I thought it was reasonably priced, but I havent put the motor back in yet to see how it runs.
Old Aug 28, 2010 | 04:01 PM
I'm in sugar land do you got a #
Old Aug 28, 2010 | 05:09 PM
Larsv8's Avatar
http://haroldsautomotivemachineshop.com/
Old Aug 28, 2010 | 06:37 PM
Kevin Blown 95 TA's Avatar
Well you should make up your mind before building the engine because pistons and ring gap and other stuff are going to be different between a blower engine and a NA engine, so if you build it for a blower than don't go forced induction on it, it may end up being a dog, and if you build it for NA and go with a blower later, it isn't going to be set up right. you need to decide what you are going to do with it.
Old Aug 28, 2010 | 07:27 PM
i know.... i want it to handle a blower but what if i dont get around to putting one on??? the way i look at it is you can put a blower on a stock motor so cant you just add it to a build N/A motor and just not get as much performance out of the blower??? correct me if im wrong because i really dont know.
Old Aug 29, 2010 | 09:54 PM
slomarao's Avatar
I am paying 2450 for a 357, TRW forged pistons, scat I beams, new stock crank, ARP main studs, balanced, hotank, hone, freeze plugs, bearings, moly rings, , Etc, etc, everything.
My stock crank would need to be taken 30 thou over just to get the grooves out. My shortblock also had to be bored t 40 over, things were bad down there.
I am supplying the canton pan and melling pump (10554) thats it. Everything thing else is in the price. I brought it to him assembled and will pickup the shortblock assembled.
I am very happy with what i am paying for the quality of the shop. I am not going boost but the ring will be gap with be for a 175 shot.
Old Aug 29, 2010 | 09:59 PM
Sounds good. I've been thinking and might build for a blower. I just got a block from my brother and am going to take it by harolds shop tomorrow and see what he quotes me.
Old Aug 30, 2010 | 04:42 AM
rskrause's Avatar
Moderator
There is no single answer to this question. The reasonable range is going to be ~$2,500 to $7,500+. You have to decide what you are building and what your budget is. Remember - the power comes largely from the top end. If you are on a tight budget, look there first.
For example, you can spend over $2,000 on block prep, and it would be worth it if you were building a max effort engine.
Rich
