??355 shortblock??
Old Dec 7, 2005 | 02:30 PM
nightrider93's Avatar
??355 shortblock??
i am starting a new 355 shortblock i am using a 1994 block from a formy and putting it in a 1993 camaro. will there be any problems with the computer or any major things that i could prevent from this being a nightmare or should it just go together like another other lt1. any help is appreciated if any one has done this before and if there are any things i need to look out for thanks thomas
Old Dec 7, 2005 | 02:45 PM
OBE1 95Z28's Avatar
Re: ??355 shortblock??
You'll be fine. About the only differences in the LT1 short blocks in regards to interfacing with computers is the use of the crank position sensor in the 96-97 setups which doesn't apply to you. You could even install a 96 setup and just not connect to the crank sensor (your harness doesn't have or need a connection).
Old Dec 7, 2005 | 05:52 PM
good just wanted to be sure before i start going crazy and buying things. thanks for the help
Z Power
Sep 19, 2015 11:19 PM
whitehooptie
Aug 17, 2015 08:35 AM
jackpawt883
Jul 31, 2015 08:15 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
